Right, I've hopefully sorted out all my issues :D
First of all, the catch can is on it's way back to Brad to be modified to suit the new intercooler piping. Hopefully I worked out where it needs to be modified correctly, but I gave it a bit more room than I thought it needed for safety. Fingers crossed it doesn't affect the catch cans functionality too much, but I don't think it will. Revised catch can will have some Earls fittings as well, so I'm looking forward to getting it back :)
Then I phoned up my local brake specialist and managed to source a replacement check valve for the brake booster, will pick that up tomorrow. After some googling, I believe I have also sorted out the throttle cable problem as well. Most people seem to have solved it by purchasing a cable clamp from a bicycle store and clamping off the cable at the accelerator pedal to keep the tension. So I'll drop into my local bike store tomorrow to see what they've got. Fitting for the IAC valve should be sorted out this week sometime as well.
Went and picked up an Earls -12 weld on fitting today, thought it easier than trying to find an appropriately sized pipe cut off. Just at a local fabricator now getting it welded on, let's hope the blokes welding skills are better than his customer interaction skills. What a traumatic experience lol.
But if it's a tight weld and it all works then it's worth it. Bought some -12 hose for the IAC valve as well, but realized too late that this stuff is not very flexible, I'm worried it will kink due to the positioning of the IAC on the Plazmaman. Will find out tomorrow :/
Edited by Hanaldo
Will do a better update with pictures etc. tomorrow, but for now... It's done. All back together, and... I'm ready to burn it. Trailering it to my tuner on Thursday to hopefully get tuned on Friday. If he doesn't finish it on Friday then it will be stuck there until they reopen on the 21st of May, so fingers crossed.
Unfortunately I couldn't sort out the injectors to get it to idle, my NIStune software doesn't work properly and wouldn't sync. So apart from priming the fuel pump a few times and fixing the few fuel leaks here and there that we found, I couldn't do much else in the way of making sure it was all correct. Means I will need to pay my tuner to bleed the cooling system and fix any other mistakes that we have made, of which I'm sure there will be many.
Also rounded the grub screw in the HKS rail as it was leaking so we tried to get it out but couldn't fit an Allen key in between it and the plenum nicely. Was one of those things where you just think it must surely be about to crack loose and then bam, the fkn thing is rounded and it's a drill-it-out job. In hindsight we should have been patient, but it's done now. Extremely pissed off about that. I'm glad it's all finished because I am done with it.
Promised pictures:
Firstly, this:
Is a much better design than this:
And that's one problem solved:
Next up, getting the fitting welded onto the intercooler pipe. What a mission and a half that was. Took 4 hours of driving around before I found someone who would do it, then the first thing the bloke says to me when the secretary (pretty little thing she was) got him for me was "waddya want ya dumb flamin mongrel?". So he had the customer service of a cave troll, but I managed to communicate with him. Lucky for me he knew his way around a tig, and this is what I ended up with:
Very happy with the end result, and that's the next problem solved. Then onto the throttle cable. I came up with an even better idea than the cable clamp, anyone recognize what this is?
It's the throttle cable adjuster off the gyro cable on a BMX. Little modification here and there, and bam:
That's another problem solvered. Had to film the throttle body in action seeing as I didn't have anyone to tell me if it was opening fully or not, so may as well upload that too:
The quick taps was me trying to dislodge the adjuster or see if it would get caught and jam the throttle open somehow, but it's rock solid. Gotta be happy with that. Now we are up to where my previous post comes in, so I'll skip ahead to getting it to the tuner yesterday. Not really a part of the build, but it was interesting to say the least so I'll post some pictures anyway :P Getting a car as low as mine onto a standard car trailer without the use of power brakes or steering is a right challenge. The front bumper had to stay off, the rest we sorted out as we went along...
Took a few tries to get it lined up, was a lot of work between two guys lol.
This is where things started to get tricky:
Very tight:
This was with the trailer parked on a slope to eliminate as much angle on the ramps as we could, AND with the front of the trailer jacked up about 50cm off the ground. Still too tight. Ended up having to get my mates mum and my dad to stand on the back of the trailer to bring it down enough to get on. But finally we did:
Then it took about 30 minutes longer than normal to get to my tuner, so we arrived at about 6pm. Luckily the guys were just hanging around having a few beers and didn't mind us being late, so they came and gave us a hand to get it off. Took 4 of us and two trolley jacks to get it off, but eventually we did and this is where I last saw it:
I was hoping it might get done today, but that was probably a bit optimistic given the extent of modification it went through and hasn't even been started yet. For all I know we did it all wrong and there are a thousand problems with it, so will just have to see. Tuner gave me a call today to say they were a bit behind and probably not going to get my car finished today. I'm assuming this means they hadn't started on it at all yet because he didn't mention anything had been done or any problems. He did say he is going to work on it tomorrow to try to get it done for me before they lock the gates for a month, so I appreciate that. Especially as he is getting married on Sunday :P
Edited by Hanaldo
Possibly time for another update...
Problems. Huge problems. I've got no idea how/why/what happened, but somehow my ECU is corrupt. Sean couldn't get it started on Saturday as the maps are scrambled all over the place. He even tried starting again from scratch, but apparently nothing made any difference, ECU is just completely messed up. As he is now away on leave, he organized with my old tuner just down the road to get it finished, and I just got off the phone with him. He has got a new ROM for the ECU, so tomorrow he is going to try installing the new ROM to see if that works, but if not then it's the ECU. In which case, I may be digging into my Europe-trip funds to pay for a Vipec V44 plug in :( Don't see the point of replacing the stock ECU again when I plan on switching to a Vipec sometime down the track anyway.
Guess it is now just a waiting game to determine whether this tune is a $500 exercise as expected, or a $4000 exercise :/
so your idle problem was just a dud one way valve for the BMC?
ive been thinking of replacing mine as I can pump my brakes at a standstill and it pulls too much vac and drops the revs etc..
Care to enlighten me as to where you found such an awesome thing?
Idle problem??? Never had any serious idle problems... I had to replace the brake booster check valve as I accidentally busted the stock one trying to relocate it into a new hose.
But if it helps, I got it from CBA :)
Forgot to update this.
Decided on Friday to purchase this:
Along with Haltech 3 bar MAP sensor and IAT sensor, so will be doing away with the AFM now too. Hoping against hope that this finally sorts out my issues and gets the car running, will find out maybe Wednesday/Thursday this week with any luck :/
It will be awesome man!!! Now you can do a nice intake pipe for more Bling ;)
It'll be good to see the results coming from both cars soon! Shame its a bit far away to cruise with you though unless the meet up point is Alice Springs? :P
Haha yehhhhh, unfortunately I don't think my car would make it that far, I couldn't even trailer it from point A to point B without breaking something :P
Will get a 4" intake pipe made up some time in the future, but for now I need to recover funds. This ECU wasn't meant to happen for another 6 months at least, so I'm running on empty at the moment :(
Yeah Mongrel is going to finish ahead of me :dry:
LOL
Good luck man, cant wait!! :w00t:
yeah but not on the track
its kinda funny as the 3 of us are basically building the same car well that is if Hanaldo dont bitch and uses e85
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
