Definitely more increases to be seen once you full run E85. I remember when i changed my car over. It went from 350rwhp on 24psi to 450rwhp on 21psi. 100rwhp gain with 3psi LESS boost!!
As you said its a total different car to drive with the other fuel in it...
Yes, but I doubt my car is going to deliver those same gains. My car loses power with more boost :/ the knock resistance of the fuel is just about at its fullest where I am, so it's only small benefits from here. I'm sure it will nudge over 400rwhp, but not expecting heaps more.
Seriously magical fuel though!
I doubt he would use 91
I think you mean the 100octance from united with 98 and 15% ethanol he is using pure E53
I believe United E85 is generally 91 octane unleaded blended with ethanol.
That isn't necessarily a bad thing though. The extra octane isn't necessary, and the lower octane will actually help the mixture to ignite. We are already talking about a 108 octane fuel here, so the octane rating of the petrol blended with it is inconsequential.
Edited by Hanaldo
No worries mate. It really is amazing stuff. Can't wait to finish off this tank and change my fuel filter, see what crud has been cleaned out :D
Also, it makes the exhaust fumes smell delicious! :laugh:
Don't think I ever posted these photos:
Got over the old white leather trims that I put in when I first got the car. Realised it looked horrible, so got some new black ones. Retrimmed the steering wheel while I was at it.
Got some new bits and pieces for my GoPro, so had a bit of a play:
1175674_10151566276907541_853880774_n.jp
1234924_10151566276892541_2118734033_n.j
1237109_10151566285662541_855149307_n.jp
1235905_10151566285672541_2063107389_n.j
Aaaaand this is a compilation of clips I've taken since the tune:
  • Like 2
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
