Will this motivate you?
Im upgrading my turbo and going e85.
You dont wanna lose to me at another powercruise do u :P?
HA! Haha! You're a funny man :P
Seriously though, if I was at all bothered by losing to people, I would have sold my car YONKS ago! Haha. My car is a perfect example of how to build a car using all the right bits, but not ACTUALLY have a fast car.
I bet you've spent less! Haha.
Quick update, flattened the last layer out today and managed to do it without rubbing through (hazzah!), so have now done the (hopefully) final high gloss coat. Used a black pigment in this one, as darker colours will show low spots better.
1798811_10151896019642541_438997584_n.jp
Will let that cure for 48 hours before I flat it down then polish it up. With any luck I'll have it finished on Monday, ready to take a mould from.
Edited by Hanaldo
Haha well I would like to put mine together first to make sure the resin and adhesive systems I'm using are suitable for the heat it will be subject to.
That said, I will be looking to start producing these if it is successful. I don't want to break any forum rules by discussing it too much, but would people be happy paying $250 for it? $300 including Speedflow fittings.
Maybe you guys can give me your opinion, I'm trying to decide whether I should make this pipe out of pure carbon fibre or a carbon/kevlar hybrid, like this:
I was thinking of doing the carbon/kevlar because I'm going to have a lot of carbon fibre items in my engine bay, I figured this might give it a bit of originality and help break it up a bit.
Thanks guys :)
So, unfortunately yesterday I sanded through my gloss coat and had to do another coat which set me back another day. But today I finished flatting it down, then sanded up to 2000 grit:
1904192_10151903313507541_617687921_n.jp
And then polished up to a mirror gloss:
164629_10151903313567541_2126259426_n.jp
1982092_10151903313657541_1958013996_n.j
I tried to take some photos that show off how damn shiny this thing is, but couldn't get the lighting right. So just take my word that it's pretty damn polished! Better than the paint job on my car, that's for sure :P
So it's ready to make a mould from now. Tomorrow I'll go get some more glass cloth and get started on that.
Well, got the barriers for my mould done yesterday:
10003082_10151907743097541_1203594129_n.
Took that picture before I had put the locators on the flange, but that's alright.
Then meant to do the first half of the mould yesterday as well, but had another set back with my tooling gelcoat. It's a bit over 18 months old so part A had crystallised. Should have checked it a few days ago, but anyway. Went in the oven for 5 hours at 71 degrees, so good as new! Had to let it cool down over night, but got onto it first thing this morning:
10015050_10151907743267541_994898819_n.j
1920398_10151907743207541_1204424629_n.j
Just need to let that cure to a tack and then I can put the reinforcement layers on.
Would you consider making one with the BOV and breather fittings as well? How does CF cope under the clamping pressure required to avoid vacuum leaks?
That is what I am planning on doing with mine. I'll be bonding in 12mm aluminium flat bar, then drilling and tapping for Speedflow fittings. Haven't quite worked out how to do it for the bov return though, I've got a GTR bov so the hose ID would need to be 1.5". Makes it a bit trickier.
As for holding up to the clamping pressures required, the carbon fibre will hold a lot more than that. The thing I need to find out is whether or not my resin system can handle the heat required. My resin at the moment can take 90 degrees before it starts to soften. So I need to go take my car for a good drive on a hot day, then turn it off and let it sit. See how much heat the turbo radiates and how much of it the intake pipe soaks up. Have got an infrared thermometer that I'll use to get measurements. If it gets too hot, I'll need to find a resin with a higher HDT.
Well this one won't really be a factory bolt on because it's 4". As pictured, it fits perfectly on my Hypergear turbo in the factory location, so depending on peoples cooler piping layout it should be a simple bolt on.
If there is enough interest, I will consider making another one with a 3" diameter. I imagine there's probably more people running that size than 4".
Bit more progress:
Moulds are finished:
1912064_10151921266877541_1658567523_n.j
Carbon layed for the first half:
1797571_10151921266962541_1571554951_n.j
Infusion stack completed and all bagged up:
1912129_10151921267047541_1121870853_n.j
Aaand infusion completed and cured for 24 hours:
1173845_10151921267137541_1780209771_n.j
I just need to post-cure for 4 hours, then I can demould to see how it went, so should have a finished half this afternoon. If it's gone well then I will infuse the second half tomorrow.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
