Cos it was NSW, you cant sent a letter of dispute to be reviewed like here in the ACT. I've tried before. You can go to court for it, and plead your case - still paying basic court costs, or you can pay the fine.
*edit* I was advised if take it to court, the judge will look at your driving history and other credentials, and there is a chance you may have your fines RAISED rather than removed.
Edited by J'son
if this one of 31 i would have just tex-screwed on to the bumper. lol
who cares if you have to drill a hole? the number covers up everything anyway. Certainly not an excuse for not attaching a plate for 4years...
Dispaying a number plate on the dash inside a high performance car is just asking for trouble IMO. Just buy a thin number plate from the motor registry and display it like I do on my R33 GTR S1 (see pic). As for the fine - I would probably just cop it and never do it again (lesson learnt). Do you really want the hassle of going to court and running the high risk of losing and then having to pay all the court costs and the original fine? Ten years time you're not going to care about any of this lol move on
Some 3M double sided tape will hold the plate on just fine. I had my GTSTs parte held on in the same spotas the above pic with double sided tape for over 2 years.just get the plastic ones made up without hoes drilled
option 1 - pay the damn fine
option 2 - pay the damn fine
option 3 - pay the damn fine and stop complaining
In terms of mounting the plate, get two pieces of metal, bend them into an "L" shape, drill holes on the bottom and the top, screw the bottom underneath the front bar and the plate to the metal. Offset it on the left or right of the front bar.
There's a boat load of adr's and shit that number plates need to comply to. Like must be parallel to the road, visible from X angle either side of the the car at Y distance from front and rear. Plate must be RTA issue and not made by ya mate at the sign shop (rapid now pick up on fake plates). Plate must be up right also not lying on your dash or on your massive fiberglass front air dam. They sell "drift spec" off centre plate brackets you screw under the edge of your bumper where you dont see, get one.
Edited by RS4-S
^ ^ ^ exactly.
In which case, the only way IMHO that you can get off is for a psychologist's report that can convince the judge that you suffer from a rare condition, "number-plate-on-front-bar phobia" or perhaps, "number-plate-on-dashboard obsession"
And just in case you are convinced that the above are suddenly plausible, it means that you're simply looking for a loophole.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
