Hey guys looking for some second hand 19" or 20" wheels for my v35 but trying to get my head around offsets?
One set I am looking at are 20 x 8.5 with a 35 offset the guy thinks. Currently on a 300zx. From what I've been reading on here the 35 offset would sit well inside the guards?
What would fit?
If anyone is thinking of selling some wheels too let me know. Looking for under $1k. Have 17" 350z wheels I may trade too if someone wants.
Edited by osiris23
  • Replies 42
I have done TONS of research on this, and in my opinion, the following are the best results to have nice flush fitment on a V35 coupe:
Front 9.5" wide +20 offset running 235/40s = no scrubbing at all - tiny bit lower offset needed to be perfectly flush, but normally results in some scrubbing
Rear 10" wide +12 offset running 265/35s, but you need camber arms to tuck the tops in a tad (which ytou want anyhow for optimal road handling under power).
Awesome site full of info and pictures :
http://rimtuck.com/s...odel=G35+coupe
And to figure out offsets, use
http://www.1010tires.com/WheelOffsetCalculator.asp
Yeah 8.5 +35 is weak as .... I mean use the calculator and compare 8.5 +35 to my fronts 9.5 +20 = they would sit 21mm further inside the guards than mine = fail. And on the rear make that 42mm further inside = horrendous fail.
But yes if you have a $1k budget you are screwed. Save up and buy a more decent set. If you can live with not-so-tough offset buy some R34GTR wheels - a set sold recently here in SA for $1,200 = cheap!
I will be selling my 20's as soon as my 18's rock up and i give the 20's a good proper clean up, only looking for $600 on them, but I am rolling them on my sedan and I'm not sure of the widths and offsets and wont be until they come off later this week. I'll let you know what they turn out to be and put some pics up when i have gave them a polish up,
Just to give you a rough idea.
I went 19x8.5+15 (245/35)F 19x10+20(275/30)R
In my opinion I think the fitment is pretty sweet not aggressive but not too aggressive.
I figure I'll only need to roll my guards if I drop it too low.. (but I intend on rolling my rears as is when I drop it)
Got a pretty good price on the XXRs too.
Just over $1k without tyres.
or just save a bit more and get a 2nd hand set of 370z 19s, last I checked going price with tyres was just around the $2k mark...
Could be less now, check the zclub forums.
No standard car in the universe has offset anywhere near what you need. You are not going to fall across a set of wheels in the size you want - you are going to actively search for wheels mate - it is hard work, and 99% of the wheels you come across will be nowhere near the right offset.
People have the impression you need to spend $3K+ if you want a set of nice JDM wheels. The markets pretty bad at the moment and there are plenty of bargains to be had.
A member here just purchased a very expensive set of Rays wheels in 19s with tires for his V and it cost way under $2K 2nd hand. Do your research and take your time. I do most of my hunting for wheels on forums and ebay. SAU, Boost, Nissansilvia etc...
IMHO for under $1K, all you are going to do is make your car look cheap, not to mention finding the right offsets to suit.
Just got my new wheels on today, sedan so will be different fittment to yours but they are 18x8.5 +25 front and 18x9.5+30 rear, rears hit the guard when i hit a bump, but will be getting the guards rolled.
^^^ Nice - I have always loved the Kai style. But don't bother getting the guards rolled - get some skinner tyres with some stretch - those puffy looking things are a bit :sick: imho
erm, where the wheel sits is to far out, its gotta be done, also those are only 245s
You are running the exact same width and offsets as mine at the moment.
Lower it by about 30mm and you will sit in nicely. I'm running 275s on the rears lowered and rolled guards.
If the OP is wondering, please don't use the sedan's offsets as reference to what suits your coupe. They are completely different.
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
