Looking at selling my r33 gtst twin turbo rb 30/ 25 combo .
Quick run down its running twin 30/37 turbos custom mainflods ,custom twin 3 inch from turbos back twin tail gates .all head work was carried out by advan performce with hks cams greddy cam gears tomi head kit ported and polished open up chamber ,arp stud kit greedy oil pump hi energy sump ,h beams rods cp pistons ,greddy oil pump ,hks oil cooler ,the rear head drain has been done ,greedy intake twin twin greddy blow off values blitz front mount .its running a link ecu .
The car was built for drag racing it has a full roll cage with mod plate its running a c 4 built by als race glides with transbrake with b&m pro ratcher kit with a pwr oil cooler ,it has all blitz oil temp boost and water gauges it has a hks turbo timmer and a blitz booster controler ,nothing has been spared on this build ,the car made 488.9rwkw on pump fuel with the manule gear and is current running 438.6 rwkw with the auto on pump fuel ,the car has been to the drags and has run a 10.4 @ 135 mph on pump fuel ,have change the suspension since then but have not race it on race fuel yet .so there is still alot more in it .
The car is located in Mt ISA QLD .but willing to bring to you with in reason ,
Asking price is $28 k but the price is ono also i no its only a r33 gtst but i have spent alot of money and time on this build so i dont need any smart comment if you dont like it then move on to the next topic .
iIf want any more info on the car plz call my self on 0419881874 Mark
https://www.sau.com.au/forums/topic/394693-r33-gtst-twin-turbo/
  • 4 months later...
I know this car well, you will not be disappointed. Been in GTR, evo, wrx but this thing takes the cake sweet car. Immaculate condition and sounds and goes like a dream. Use to be in Townsville with the same current owner and is still for sale in Mt Isa.
Free bump.
Edited by jbute
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
