I've been messing with my consult on and off for ages now but have never got it to work.
I have a S2 RS-4 S and am trying to use one of those cheap Chinese consult adapters.
I am pretty sure my ECU is stock, my consult port has a yellow Tx and a brown/yellow Rx wire, no clock wire and a black ground. I havent seen those particular colours on any of the pinout diagrams but I assume doesn't matter, and I have read Pete's posts before that no clock on the RS-4 S is normal same as the R34 Gtt.
I have so far tried ECUtalk windows XP and 7 laptops, a Windows CE mobile device. As well as writing my own python program in Linux that works similar to Hyper Terminal. I have used 2 different Serial - USB converters one of which is FTDI based. No luck on anything so far.
When I use the terminal program it works fine transmitting to itself and other systems so the Serial comms side is fine, when I turn the key on the Stagea to ON I receive a 0x0 hex character, but no initiation string I have used so far has yielded any results. While sending random hex chars to the consult port (while the Stagea isn't running) sometimes returns different hex characters so I am assuming the consult adapter I am using is working.
I was hoping Pete or one of the other more experienced members could give me an idea on what the problem could be, I'm running out of ideas.
https://www.sau.com.au/forums/topic/394705-consult-problem-rs-4-s/
