You are looking at a a brand new Intel Core i5 based PC
SPECS
- Intel Quad Core i5 CPU @ 3.1GHZ ****HOT****
- Dual Channel 8GB DDR3 RAM
- 24x DVD/RW +/- Burner
- 1TB SATA III 7200RPM HDD
- Built-in Audio and Video
- 6 x USB 2.0
This computer is a extremely powerful PC and perfect for home or office applications such as internet browsing, Games, email and Microsoft Office plus much much more.
This computer is designed for the latest version of Windows 7 and exceeds all recommended requirements.
Comes with windows XP
Any version of windows can be supplied and pre-loaded.
Item can be shipped anywhere in AUSTRALIA - Contact me for up to date detail pricing.
Pickup available
$510.00
0405042044
[email protected] Email proffered, But SMS and calls are also fine!
Thanks.
Edited by Cre8toR
All good and done writing basic spec notes like that but what are the detailed specs.
What specs does the ram have ie: speed, timings and what size per stick.
What about the CPU what actually CPU, is it a K or is it locked.
What motherboard is it.
Why state it built for windows 7 but pre load it with xp.
Further note to that which xp does it have; Home, Professional, 64bit or Enterprise.
This isn't Harvey Norman need some detailed specs please.
Also does it come with a KB & M and a monitor ?
I hope you're interested an not just wasting my time!
Ram is 1,333MHZ dual channel 2x4GB
i5 2400 3.1GHZ that can be clocked to 3.4 I think
The motherboard is a MSI MS-7680 with shared Vid and Sound but a Graphics card can be added (I can do this)
Apart from that I can go on with useless info for ever- Maybe you could just ask me some questions and I'll happily answer them!
Pretty sure it is unlocked.
MS-7680
I built it so I could download movies and watch them on my TV, It's connected to my 52", XP is all I need for this, I can offer Windows 7 but you will be paying or using your "Product key" Not mine.
64Bit as 32, can only run 4GB Ram
It's not Harvey Norman but a car site.. People here know about cars, Ask me some questions!
Tower only! I can the other items as I can get them cheap but you will be paying extra for these. How ever I can help!
Edited by Cre8toR
I may have interest but I was looking for a cheap complete system as I cbf building one myself I can also get parts cheap (work in wholesale).
Other things I would like to know is what chip set is it z68,p67,h61 etc etc
What brand is ram ?
Honestly cannot remember what ram it was, I think it was G.Skill.. Ram is the cheapest part of any build bud apart from the rom..
It is a H61 chipset too, I can do complete computer packages, Like ive said TELL me what you want, I do computers on the side and custom build.. I just had thi unit pre-built and no longer need it.. You wont find cheaper.. Go look! it's been used for say 30 hours max? It's for movies so just gets turned on for a few hours here and there.
What size screen etc do you want and I'll price it up for you.
Cheers
Edited by Cre8toR
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
    • No idea. It's too weird.
    • The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
