arent the m35 wheels 18x8 +38?
if so they are close to the same fitment of a r34gtt/ r32gtr stock wheel.
they wont even fit on a rs4s without a minimum of 30mm spacers. (i run 30mm spacers and i still have 2.5cm gap between the tire and my guard)
cant say anything for the rs4v tho, since they had a wider track they might sight a bit more flush
My RS4S came with V35 rims 17x7+30 and 17x8 +33 from memory.
It also came with 26mm spacers, remove the spacers and the rears rub the strut while the fronts look retarded.
Yes my tyres ruin Attesa and i run in 2wd most of the time.
Added this for reference, I think these rims may also have been poverty spec M35 rims...
Edited by shane344
V35 17's look similar, until you put an M35 rim next to them. The M35 17's are 17x7, +45 offset.:sick:
There is no concavity in the spokes of the M35 rim; the face is basically flat.
And they look poo.:/
Edited by Daleo
  • 2 years later...
Sorry to be bringin up an old thread, I do it too much.
I'm looking at buyong some 18" arx wheels for my series 2 auto c34 rsfour, I'm hopeless when it comes to wheels and I'm just wondering if somebody could shed some light on this for me, I believe they have a similar positive offset so I'm alright with that but is there anything that will really kill my car runninh them? I need a lower profile tyre to fit these wheels I think, unless it's something to do with the difference in size making my awd have a spaz?
Sorry for the essay and the half questions but I really don't want to drive an hour to have them not work at all
ARX rims are all the same size so wont affect Attesa.
Not sure about V35 rims but my V36 rims and tyres were wider on the back than on the front and would be a no go for the Stagea 4WD.
As long as all 4 are the same then Attesa will be happy.
These are 18s off a v35 Skyline GT Coupe Sport Edition (with spacers). I believe the M35 will fit but may need bigger spacers. With 40 profile tyres they are a bigger rolling circumference than the C34 wheels but the speedo is pretty much spot on.
Shameless plug alert; FYI, I have a set of V35 Premium rims as pictured above for sale. They're just sitting in my garage collecting dust. Came with my AR-X as spares. Located in Epping, NSW.
Check your pm's blek
  • Like 1
I found a thrashed 225/40 18 outside at work and test fotted my arx wheels and all ok. No spacer needed. I had to got from and 50 profile down to 40 to clear everything but all good. Enjoying the look of 18's as well.
so for future reference m35 arx 18" wheels are fine with a 40 profile, my rolling diameter is almost spot on factory as well
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
