EOI
Basically, thinking of stripping my r33, there are a lot of parts, aftermarket and standard. I will list some of the major items and if anyone is interested please PM me and if I get enough interest I think ill let the memories go and start pulling it apart. The car was never completed, everything is mostly bolted on however never started or tuned as I started working a lot and the whole project went out the window. Now I'm trying to move up with my career and just don't have the time for it anymore.
I am open to offers on all parts.
rb25det s1 motor, complete minus turbo/manifold etc, compression 145-160 on all 6 cylinders - $1500
(made 194.6kw with std. turbo on 12psi with full exhaust and intercooler so very healthy)
rb25det s2 gearbox 86,000kms on it - $1500 or as a manual conversion kit $2000 (everything you need)
HKS GT2835r turbo (420hp rated, seen couple track days since rebuild made 290rwkw on another car) kit including HKS cast manifold, Greddy ext. gate, screamer pipe, dump pipe, steel braided lines, turbo intake and hot+cold side piping in lobster back stainless steel by AM Performance - $2200
AM Performance cat back exhaust system 2x2.5" in to 2x4" pipe with titanium tips - $900
VQ35 ecu with rb25 nisstune board (lets you use vct unlike RB20 ecu)- $450
Yellow Jackets coilpacks for s1 rb25 (all working, used for 1 year, fantastic coilpack, search forums) - $250
Power Enterprise 850cc side feed injectors to suit rb25 in rail, brand new - $750
ORC Single plate clutch, 409 series unsprung center, used for 6months still in good cond - $400
Greddy copy plenum kit (rb25 throttle body adapter, nipple fittings, hose fittings, hoses) brand new - $350
External fuel pump setup, 2L tank + bosch 044 with mount and all fittings + ethanol fuel hose, brand new - $350
Wlabro 550hp intank pump - $100
R33 Non-sunroof 9point cusco D1 cage, through dash with side intrusion bars and padding - $950
R33 brake setup, hubs, slotted discs, calipers, a1rm pads and adr approved braided line - $800
R33 BC BR Coilovers, used for 4000kms, like new - $900
R200 locked diff, tight as - $200
Kazama castor arms suit r33 and other models - $150
Rear camber arms unknown brand, brand new - $100
Hicas lock bar - $80
R32 genuine GTR intercooler - 150
Rb20/25 hybrid intercooler kit, core is rough but no leaks - $150
z32 afm with plug - $150
q45 afm - $80
Work VS-XX wheels, 18x10 +13 front with kumho ku36 tyres 60%, 18x12 -4 rears with bridgestone tyres 40%, not for groupies or wanna be's... need some serious guard work to fit these babies. Genuine 3 piece - $3000
And everything else that you could think of, suspension arms, lights, dash pieces, trims, looms etc etc... im sure I missed a lot of little aftermarket things but those are the major ones listed. If I go ahead with it I will list all the parts and pictures as its taken apart.
Also, clean registrable r33 shell/plates.
If youre interested in anything PM me, when I have enough interest the strip show starts.
Edited by SkyHi_33
https://www.sau.com.au/forums/topic/394832-eoi-stripping-300kw-r33-gtst/
No std. steering wheel, ive got a momo drifting suede deep dish, and two no brand deep dish suede wheels, one black one blue.
Haha its a very nice exhaust, $1550 from memmory new and its barely been used!!!
Ps. Cant reply to pm's off the phone sorry guys, ill get to it asap!
I can get pics of most of the items, the plenum is brand new. Ill wait a few days till Ive got enough interest and if there is, then Ill post another for sale thread with all the pictures of parts.
Im located in Adelaide, SA. Marion area. The shell is in primer and needs a bit of body work but its straight.
Steering wheels, I dont want to sell the momo just yet but the other two I can do for $80ea + postage, theyre brand new in the box still.
they look like this (same wheel on a mates car)
http://s2.photobucket.com/albums/y33/kfsRule_2/?action=view&current=steeringwheel.jpg
Edited by SkyHi_33
I havent got any pictures of most of the stuff atm, still deciding if I want to part it out. Have had a fair bit of interest so at this point I most likely will.
The rear arms are adjustable, and yes still got the engine loom.
As I said, Ill leave the thread up for a week or so, I've written down everyone's usernames for people interested in parts and will PM you in a few days when I figure out what to do with the car. In the meantime Ill try get a few pictures :)
Thanks!
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
