UPDATED LIST OF PARTS AVAILABLE
Still got these parts to clear!!!
Can get pictures of everything on request.
rb25det s1 motor, complete minus turbo/manifold etc, compression 145-160 on all 6 cylinders - $1200
(made 194.6kw with std. turbo on 12psi with full exhaust and intercooler so very healthy)
rb25det s2 gearbox 86,000kms on it - $1500 or as a manual conversion kit $1800 (everything you need)
HKS GT2835r turbo (420hp rated, seen couple track days since rebuild made 290rwkw on another car)
kit including HKS cast manifold, Greddy ext. gate, screamer pipe, dump pipe, steel braided lines,
turbo intake and hot+cold side piping in lobster back stainless steel by AM Performance - $2200
AM Performance cat back exhaust system 2x2.5" in to 2x4" pipe with titanium tips - $950
Yellow Jackets coilpacks for s1 rb25 (all working, used for 1 year, fantastic coilpack, search forums) - $250
ORC Single plate clutch, 409 series unsprung center, used for 6months still in good cond - $400
Sparco sprint + R33 drivers rail 2 months old $650
Sparco Evo 2 Plus seat, no rails, brand new $500
Wlabro 550hp intank pump - $100
R33 BC BR Coilovers, used for 4000kms, like new - $900
KTS Sway bars front and rear with bushes - $350
R200 locked diff, tight as - $200
Kazama castor arms suit r33 and other models - $150 SOLD
Rear camber arms unknown brand, brand new - $100 on hold
R32 genuine GTR intercooler - 150
q45 afm - $80 SOLD
RB20/25 Short Shifter - $50
R33 Carbon Slam Panel/radiator cooling pannel - $100 on hold
R33 Nismo strut brace with brake stopper $180
Pineapples - $40
s2 dash surround with vents, buttons and clock, mint $100
s2 door trims with switches, mint $150
Work VS-XX 3pce wheels, 18x10 +13 front with kumho ku36 tyres 60%, 18x12 -4 rears with bridgestone tyres 40%
Just dropped two off to get re-polished and some rash taken out, may even re-powder coat the centers for those interested. Will be as new $3200
Make me an offer!! Im pretty reasonable, the worst I can say is no smile.gif
PM or 0422 314 938 - Marko
Edited by SkyHi_33
Also, im going away overseas in 3 weeks so want to clear everything!!!
Have all standard parts still on the shell, door trims, interior bits/consoles, engine bay stuff like brake master, clutch master, steering rack, alternator, starter motor, power steering pump, standard suspension arms, body panels, bonnet boot doors guards lights etc.
Everything must go!!!
Will be taking pictures of everything tomorrow and posting it up in here so keep an eye out, anything youre interested in PM me, Located in SA but can post anything anywhere!!!
Edited by SkyHi_33
Bought the R33 brake setup from Marko great guy to deal with sorted everything out including shipping and sent me heaps of pictures. Would definetly recommend him as a seller =] thanks you for pleasant smooth transaction.
Item was as described and pictured and boxed properly with all the parts/bolts.
Edited by DarkRyda
still got the z32, rear camber arms, castor arm and lock bar? pm me if so
Sorry, z32 and castor arms and lock bar are all sold, camber arms on hold! Will let you know if it falls through.
Thanks Justin, was a pleasure. Loving what youre doing with the brake kit and your car :)
Edited by SkyHi_33
Hi mate, is this a series 1? if it is i'm quite keen on the bonnet provided you still have it and can ship it to wa 6155 (at my expense of course)
Just let me know
Cheers
Nev
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
