when i start my rb25 the idle will drop down to about 400 then raise back up to normal idle, but today it just stalled and was almost stalling after starting.. also when i just lightly tap my accelerator it will bog down a little and run rough for a second, any ideas? bad air filter or fuel filter?
https://www.sau.com.au/forums/topic/394837-poor-idle-after-starting/
i have the same problem aswell,every time it gets cold or left for hours and go to start it it will sit low at around 300rpm and then raise up or even stall most times and now is worse as every time i start the car when cold it stalls unless i give ii a lil rev..its like blocking up for a couple of seconds and clears up.
afm cleaned,new filter,plugs.....havent done the fuel filter as yet but the aac valve was cleaned a few month back...cant work it out :/
There is a screw on the aac valve to adjust the idle - pretty sure its in that thread i put in the link above..
Resetting the ecu may help.. IIRC - take negative terminal off... pump the brakes for a bit to drain any charge still in the system.. connect negative back again (your clock etc should have reset if you did it right) There is a quicker way of shorting the ecu in the fuse panel under the steering wheel (never tried it)
http://www.skylinesa...1900-reset-ecu/
Edited by defari
Does this only happen when cold?
Do u have stock ECU?
One of my cars does that and its because i have a power FC and it hasnt been tuned for a cold start, also needed new wax pellet.
Also as previously suggested, definately check / clean AFM and AAC, plugs, coil packs.
Edited by iwanta34gtr
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
