Looking at a Tomei Extreme Ti cat back exhaust system but want to confirm what the ID of the rear muffler is. Has anybody actually seen one or own one...measured one?
I understand the tube diameter is 89.1mm OD, just want to make sure the muffler does not drop in diameter to 3" etc
  • Replies 100
Yeh, but if I am spending that much money on an exhaust I dont want it to cost me a single bloody kw. I only make 250 odd :( I have some prices for some thing guage stainless mufflers and pieces and if I cant get a solid answer on this exhaust will be going twin 2.5" with a 4" dump with wastegate plumb back in. I currently lose around 6-7% of my power when I plumb the gate back in so need to improve over the HKS Hyper i currently run
the solution to your power woes??
open up that screamer :thumbsup:
fab up a removable piece so you can remove it and reinstall at anytime which shouldn't take long to do.
I don't know how anyone can drive on the road with a screamer, I only lasted a few days of not being able to boost at all for fear of instant defect, car crushing, death by firing squad on the side of the road. But then I do live in Victoria...
Tracks have DB limits too, on some cars they dump the exhaust out different sides depending which side of the track the pits (read microphone) sits. An open screamer would have no chance.
must be a Victorian thing.
Wakefield and Eastern Creek in Sydney, don't have noise restrictions.
wakefield does have noise restrictions, there is a mic in the middle of the grass patch near the main straight.
but they allow open screamers, your car must be insanely loud for them to pick it up and kick you off the track.
ok i just checked the wakefield regs, it says max limit is 95dB at 30m,
they must be very lienant with this as ive seen alot of GTRS/V8/cars with open screamers go there without an issue.
Noise can vary in DB with something a simple as a wall.
Most tracks have restrictions. And then also some have "X" amount of "unrestricted" days.
Just a matter of if you get pinned or not, and that depends then on the position of the pickup
Bris, Buy a 3.5" Borla/Magnaflow etc Stainless muffler from Summit/Jegs take to a decent exhaust shop and have a system made made, wont be titanium, but wont be any doubts about the muffler quality either
+1.
In fact just got a new full 4" system using Magnaflow's Troy. 6" body Cat as well. Worth thinking about - at least you know exactly what you're getting.
I'm a jdm fan to my detriment with some of the parts I buy... Incliding exhaust's for the most part.
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'Burns Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'Burns Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'XXXX Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'XXXX Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
Don't go posting this stuff up on SAU. The real good gear you need to keep quiet and to yourself :) I did an exhaust with a friend years ago when I lived in Sydney and had after hours work to my old employers factory, tools etc. Their gear is top notch and I was planning on using two of their real mufflers in a twin system.
What I need to find is a centre muffler that has a 4" inlet and twin 2.5" outlet
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
