  • Replies 100
PUt mine on dyno ready for e85 and clutch slip so lucky i had a spare nismo twin sitting at home , put in this week and try again :)
but to fair you knew it was going to happen cant wait to hear the exhaust on dyno going to loud bouncing off the wall.
can anyone suggest some cams for the more lumpier sound?
have a fully rebuilt engine -5s etcL
Lol you don't buy cams cause u want a lumpier sound......
Get your tuner to lean it out at idle, and I think they do something with timing. There's ways to make em sound lumpy, if that's what your into
With the piping going smaller wouldnt that cause a bottle neck in your exhaust flow? Especially if your after big power? Im currently looking at getting this aswell but i dont want any bottle neck's in my set up.. I'll be running 20+psi and will be looking at trying to max out my -5's on E85.
Im going e85 0n my -5s now to , i have hpi dumps , sunline ti front pipe , and the tomei ti cat back , i dont think there will be any restriction but i will tell you in a few days and post a vid of it at full noise on dyno :)
Please do mate! Seems like we are bothi doing the same thing. I also have HPI dumps, 3.1 front pipes (Non Ti) currently on the hunt for a cat-back and i will be going for my E85 tune.
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
