I have a few questions which may be silly - but I'm willing to ask the dumb questions for the knowledge :(
- Is a stock R33 GTR speed limited to 180km/h like Gtst?
- Are slotted front rotors standard?
- Is the carbon fibre surround standard for the 3 gauge set (front torque/oil temp/boost) on the 33GTR?
- On the pic below of my oil gauge where is the 'safe' range? I would assume where I put the blue marks (in the white bracket would be safe?) Does anyone know what the temperature is of the top white line of the bracket?
- On the pic below I have no idea what this black piping is between my radiator and my intercooler, this photo is from under my car, taken from the passenger side looking across, you can see my intercooler at the front, then the black pipe (doesn't look like its stock) then my radiator behind that... any ideas?
Thanks for any help :)
https://www.sau.com.au/forums/topic/39487-silly-questions-about-my-gtr/
Yes, it is.
-Are slotted front rotors standard?
No, they are not.
Yes, it is.
A bit of guess work is involved with the stock oil temperature gauge. I would say the top of the white bracket you are referring to, is around 130 degrees which could be considered as too hot for prolonged use. You will notice, if you go for a spirited drive through the hills, it will get there fairly easy.
Looks like a non-factory blow-off return line.
Thanks for the replies
I have had the oil temp up to about 3/4 of that white bracket at which point i started going a little bit easy on it to let it cool, generally it sits at about 1/4 of the white bracket
Any ideas why it would have a non-factory blow off return line? purpose of it? (as opposed to the standard one)
viewing from the 77 views and the 3 replies maybe my questions weren't as silly as i thought..
Emre answered them all... but im still interested in feedback about my last 2 questions - oil temp and the black tube if anyone knows :)
Oil temperateure can be an issue in GTRs Ferni.
As you've confirmed it's not a hard task to get it up on the gauge, especially if you are having fun through the hills and sitting on 5k rpm and above. Things get worse on a race track, so if you find yourself in the position of cutting your fun halfway through to let it cool down, definitely invest in an oil cooler.
Synthetic oils of today do an admirable job and withstand temperatures of upto 130 degrees and maybe beyond beriefly, but the value of a $1000 mod in the way of an oil cooler could not be denied.
Re: Your non-factory blow-off return line.
It's possible that one of the previous owners may have had blow-off valves venting to the atmosphere and during the installation all the factory plumbing may have been thrown away. So, when returning back to the factory set-up for one reson or another, they would have costom made new piping. It's really not a big deal as long as you have a pair off blow-off valves functioning as they were intended to.
Emre - thanks heaps for your help :D
Yeah exactly right as i'm driving up the hills and/or keeping rpm up aorund 5-6k i can see the oil temp rise... I do have fully synth castrol formula R 10w60 in... I guess i should see how often it happens, if i find myself in that top 3/4 braket often i guess i will have to invest in an oil cooler... if its only rarley i will just ease off when i see it hitting that top 3/4 bracket.
if that is the blow-off return line then where should it be coming from / going to?
The air trapped in the intake (plenum, cooler, piping after the turbos etc.) when the throttle is shut is vented out off the system by the blow-off valves.
The factory setup returns this air back to the inlet to be combusted, hence the reason they are called plumb back. They can still be quite audible.
You have to pull the liners in your guards to have full excess to all the plumbing.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
