Hey ron!
I joined in 06.
Ives seen some familiar faces come and go in the last 6 years!
I remember when you were active on the forum, it is going back some time tho.
As terry asked, what are you driving? and are skylines still a passion of yours?
Cheers adam
welcome back :)
EDIT: err... i just checked my joined date, i see your October '02 and raise you.... :D - man, had no idea it's been that long. Crazy
Ron, did you come over from SDU? that's the ORIGINAL i guess :D
Hi guys, yeah been away for a while but really this is the only forum I feel like home.
I still remember back in the days of SDU, and yes I was on there as well.
Also remember the days skyline owners used to just flash hibeams as we past one another (back then Lines were rare, got mine in '99)
I dont have one anymore but still love them to bits, whenever i see all you guys' cars boostin up the street it still give me goosebumps and bring back memories.
I m a tradie now so i drives hiace van everyday, but couple time a week i get to jump in my miss's R36 family car. Til E63 comes that is, just waiting to test drive the current one with 5.5TT
pffft.. damn old timers.
Dam straight :whistling:
Remember SDU well. I joined it in around 1999 - 2000. Still had my R31 GTS2, and was starting to shop for my GTSt.
Fondest memories were arguing with the chequebook racer from hell who claimed that all his developments were his own design / idea (even made some claims insinuating that his ideas were taken up by Cosworth when he got them to do some development on his GTR). Of course back in those days if you dared to question anything he said you'd get shot down (and banned) by his fanboi club. I won't mention any names, but I'm sure those from that era will remember him well.
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
