This calculator is better than the one I have posted earlier:
http://www.wallaceracing.com/etcalc.php
Although the 60' and 1/4 MPH inputs might not apply accurately to AWD turbo cars (more NA and dedicted drag cars)
sky30, I would suggest that you will require approx. 430-350rwkw with a 1.5 60' with 6.25-6.3 1/8 mile ET to equate to a 9.9 sec 1/4 mile ET
Hoping to make another 30kw so mite be getting close to enough power needed.
I have played around on thise calculators with some if my previous cars which i raced on 1/4mile ( back when sa had one) and they always show slower 1/4 for any given 1/8 time. Think they are based on v8 n/a cars. Turbos having more topend may be slightly faster.
It is interesting that Mr Hodgson (2Rismo) ran a 10.5(ish) at 135(ish) with 330rwkws in his 33 GTS-t, tis an auto with a bigish converter though
hopefully he will pop his head in with a half track time.
auto should have less trap speed but a better ET (in a perfect world)
and 100kgs should only mean a couple of tenths at best
which is why it interests me
Although with that should of power most guys would be pulling 4th in a GTR at around the 1000ft mark yes?
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
