I am selling my r33 gtst as we have a second child on the way and its not really practical. Have current RWC. Asking 10k for a quick sale. Not really looking to budge much. Its advertised eslewhere for more. This is my no BS, come buy a great car price.
R34 gtt wheels,
New GT radial rear tyres,
Brand new BC coilovers,
Adjustable rear camber arms,
Solid diff bushes,
Stainless 3" cat back Fujitsubo exhaust with huge mid muffler,
Pod filter,
Autometer digital boost and air fuel ratio gauges,
Carbon fibre ducktail wing
Clear side indicators
Aftermarket heavy duty clutch.
Huge fuel pump.
Hicas lock bar.
It has had the power steering reservoir relocated and custom made braided lines made up. This allows enough room for a high mount turbo setup to be installed.
The car has had a full cosmetic respray a few years ago and is one of the cleanest skylines I have seen. It has recently had a major service including new iridium spark plugs, new gearbox and diff fluid, oil and fliter change. New fuel filter and fuel lines for engine bay. New pod air filter and adaptor. Full coolant system flush and replaced with new long life Nulon coolant + new Gates hoses. Has had a lot of the original vacuum lines replaced with silicone items. There is over $600 in parts here alone.
This is a beautiful car to drive and its very nice on the road. The suspension work makes it fun to drive but isnt too harsh for day to day driving. The exhaust isnt just a cannon. It's a full high quality stainless system that is quite subtle. It has an alarm but im not advertising what type it is.
I get at least 500k's or 10L/100km to a tank with city dirivng. It shows how good the motor is and how well its been looked after.
I may be interested in a swap for a family style car (civic / accord euro / mazda 3/6 / liberty / falcon or commodore or try me for others) or an evo / aristo / legnum / caldina. Could also use a dual cab ute to start up a side busness for while the wife is off work.
Contact Dave on 0424506009
Edited by coaster
Sorry, its done 170km's.
no the timing belt and pullys havent been done that i know of. happy to discuss getting it done or including a kit for a potential buyer.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
