Massive Silvia And Skyline Parts Sale Cheap Stuff!
LOTS OF PARTS FOR SALE!
SR, CA, Z32, RB20, RB25, RB26!!
Pics for everything available on request, or find pics in here: http://nissansilvia.com/forums/index.php?app=classifieds&module=core&do=view_item&item_id=4506
CHEAP!
Here goes:
> RAYS Gramlights 57s pro titanium 19 x 10 + 22 - $4000 inc centre caps and top of the range potenza Re001 tyres 99% brand new
> Nissan turbo timer plug in harness - $10
> 180SX headlight vertical support left - $20
> 180SX headlight vertical support right - $20
> Blitz SR20 Air Filter includes AFM mounting plate - $30
> SR20 Knock Sensor good - $50 second hand
> SR20 Knock Sensor BRAND NEW $175 genuine
> Silvia turbo Oil Line - $10
> Silvia turbo braided oil line - $20
> Silvia turbo Water Lines - $10ea
> SR20 Starter/alt gearbox loom - $40
> Silvia Hot Pipe turbo - $10
> T2 Laser Cut flange - $20 brand new
> T25/28 Laser Cut Dump Flange - $20 brand new
> Silvia Belt Buckles - $30/set of 2
> S13 Belt Reel D/S - $20
> S13 SR20 interCooler Bracket - $5
> S13 ign switch - $10
> S13 engine battery earth cable - $5
> S13 SR20 egr tank bracket - $10
> S13 rear calipers with good pads and lines - $40
> S13 e brake - $15 inc rubber cover bit
> S13 climate control loom - $50 inc relay!
> S13 centre bearing bracket - $5
> Screamer Pipe! - $10
> S13 castor rods ready for bushes - $20
> S13 Front Brake Lines not cracks - $10
> S14/S15 good rear discs - $20
> CA18 Alternator - $50 good working
> S13 ca18 clutch master slave and pipe - $20 no leaks
> S13 rear knuckle right - $20
> S13 rear knuckle left- $20
> S13 Handbrake Cables - $10 ea
> R33 GTSt Handbrake Cables - $50ea
> 180sx fuse box cover - $10 ea
> s13 door loom - $15ea
> s13 side mirror interior plates not broken - $10 ea
> R33 GTSt rear lower control arms - $30ea
> R33 GTSt rear upper control arms - $30ea
> R33 GTSt rear traction arms - $30ea
> R33 GTSt 5 stud hubs - $100pair
> R33 GTSt handbrake assembly inc shoes and clips backing plate etc - $75
> R33 GTSt rear knuckle no backing plates - $50ea left and right
> R33 GTSt drive shafts 5 bolt - $50ea left and right 2 sets available!
> S14 drive shafts 6 bolt - $50ea
> R33 GTSt good stock shocks no leaks - $25 ea
> R33 GTR carpet good nick - $50
> GTR knock sensors BRAND NEW 2 of them from nissan - $300
> R32 GTSt GTR strut brace - $50
> 300zx Z32 air flow metre BRAND NEW! - $285 with plug not neg
> 300zx viscous diff non turbo 5 bolt! - $150
> 300zx drive shafts 5 bolt - $50ea
> RB20 gearbox $300 - typical slightly noisy cluster bearings - synchros and gears mint though. cheap fitting available in melb.
> R32 or R33 gearbox crossmember - $30
> RB gearbox mount - $30 non awd one
> RB clutch slave cylinder - $30
> RB crank angle sensor BRAND NEW - $370 suits all rbs with minor mods to R34 models
> RB26 Carbon timing cover - $125 not from ebay! better unit!
> RB26 Painted timing cover - $150 mint!
> RB26 rubber Intake Pipes - $50 ea
> RB26 Intake valves good condition - $15 each
> RB26 ally intake pipes with 2 bolt holes - bolt on front of turbos - factory ones $50ea
> TR29 Turbo - used for 5000km PERFECT CONDITION - $300
Located in melbourne, can post everything, at your cost.
0400 558 030 after hours only if youre calling.
No time wasters FFS!
I only have these parts please dont ask for anything else..
Cheers,
Mat.
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
  • 3 weeks later...
 Share
