hey guys,
got the car back from the tuner the other day, he said the stock turbo has about 15,000 klms left on it depending how i drive it. i am looking at just replacing it with a factory one again BUT i was wondering:
is there a DIRECT REPLACMENT bolt on turbo aftermarket? not a nissan one? to potentially get more power later on?
Thats crazy that they know how long the turbo will last, what are the reasons it will die?
Thats what I was thinking lol, pretty advanced to be able to tell 15000km left from the noise. Anyway in regards to your question I also suggest just hiflow it and youll have a new better than standard turbo, whats to say another stocker youll buy isnt on its way out soon aswell.
If it is a stock turbo and the bearings are already on their way out, there is no telling when the ceramic wheel will start hitting the housing and the ceramic wheel ejecting itself from the shaft and taking the engine with it via ceramic dust (GTRs more susceptible) or the wheel safely ending up in your cat converter.
ive enquired about a turbo for sale on here, and maybe picking it up next weekend. its a r34gtt turbo the op6 rear housing one, i heard its a stright bolt on swap. is that good to use? no detonation? can i just fit it and get no tune? will it run on stock boost from this turbo?
Yeah I was gunna say this how the shit could they determine that
They must have a "bearing wear detecting flux capacitor "
Hahahahahah
It's a slightly bigger rear housing on the op6 tho they have a nylon front wheel aswell apparently only good for 10-12psi tho it's debateable
U might get away with it but if it was me I'd put it on the dyno
It will work. And if you ever high-flow it you will get an even better result (they're slightly bigger than older RB25 turbos).
Yeah I was gunna say that also .
If u get it retuned with that turbo u may make a squidge more power due to the better flowing rear it will also be a lil but lagier I would think
If you are going to just whack a stock turbo on, then the R34 would be the choice, it's ball bearing and will be less likely to eject it's ceramic wheel due to age vs a R33 one.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
