So I have slapped on some hard compund Hankook Ventus TD Z221 for Phillip Island. I also have a set of 295/35/18 AO50s but think I am in for all sorts of trouble to get them to fit my car.
Has anyone fitted the 295 AO50s onto a 9.5" rim ? Or do they really need a 10" rim?
Looking for semis for my GTR. Essentially want something that is going to last a few track days but won't take forever to heat up. Also, the cheaper the better :)
I have yet to buy rims yet but I was looking at 18x10, so would 265/35 be the best profile? I am not finding many semis in that size. Should I look at other rim/tyre width combinations?
Need to fit V8 supercar alcons underneath.
Cheers
Cheers
I'm in the same boat as you except my rims are 18x9.5. I've found a fair few tyres that would be fine but I can't afford them at the moment so I just started snapping up the used 265/35/18's off ebay.
I might start off with that as I don't think I'll be getting the full potential of new semis just yet. How do you find the used tyres? What do you look for when buying them?
Ahem - surprised no one has snapped these up yet:
http://www.skylinesaustralia.com/forums/topic/423228-syd-28530-18-dunlop-dz03g-sparco-slalom-sl-3-racing-boot/
And I have 295 30 18 A050's on 18 x 10's. Seem just fine and fit under the guards of my 33 GTR - hint hint Fatz.
I have 245/35 on my 18x9.5's at them moment and they are stretched hence the step up to 265's.
I just put 265 18 into ebay or semi slick and see what comes up. I picked some up earlier this week and now i'm just waiting till some more come up at a decent price.
No clearance or rubbing issues with 295's Eric?
I have a brand new set of R888's at home in 265/35/18 but am considering snapping up a set of 295's I have access to instead, and was wondering how they would be on an 18 x 10.5 rim.
  • 2 months later...
Need your opinions guys...for the same money...would you choose:
1) Toyo R888s 275/40/17
or
2) Hankook Z221 255/40/17
Tyres are going on 17x9.5" rims front and rear...are the Toyos really as bad as people make them out to be?
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
