I've got them on 9.5s on the rear, and wouldn't call them stretched.
265s would be better for a 10" wheel, but these are cheap and basicaly full life left in them....
If only i hadnt just purchased a house :( Ill just run the RSR and learn to drive haha
Yokie AD08R's. Anyone know anything about them?
I used them on my old green Gts-t. Managed to match my RE55 time on short track in a high powered rwd skyline so they grip like crazy for what they are (a few suspension changes at the same time so that would have helped)... Not a semi by any stretch but you wouldn't lose time a whole lot of time compared (maybe 1.5sec slower)
Hey guys I'm going to be using the ku36 kuhmos as steer tyres on the drifter just wonderig if anyone's had experience with them, I think they are more of a sticky stret tyre than a race compound, I'm restricted to 205/50/15 in size, main reason I wanted stickier tyres on the front is to reduce understeer
Are you looking for a good street tyre, or a semi slick for circuit use. They are a good street tyre.
If you are after a semi slick the 15" rim will limit you, but it also suggests you have a light car. Look into Toyo 888 and Kumho v70a. They will be nice and cheap in those sizes too
Sorry forgot to say what car it is, it's a s13 Silvia , fully stripped and fitted with an rb25 , i can't see it weighing over 1100kg.
It's purely for drifting and I only want them on the front , was hoping that because they are a street semi they might last me longer than a race compound, also there design allows for use in damp conditions.
My main concern is weather I should have stuck to 17's and weather a 235 or 245 would have provide a lot more grip on the front , for the past year I've just been using cheap tyres like durun and sunny 235/45/17 as steer tyres, hoping that a reduction is size will balance out with the quality upgrade of tyre?
Best bang for buck Druncan ?
Haven't bought a set for a while, and last time I did the Federals were definitely the thing to have for the money. But I see Harry's warning that they have changed for the worst since.
I'd probably go Kumho V70A again, they worked well and didn't require me to sell drugs to fund them like yokos or dunlop.
  • 3 months later...
Anyone tried the BFGoodrich g-Force R1?
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+R1
It's not far off a full semi and they are pretty cheap. what do you guys think?
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
