Those Nankangs look pretty good, unfortunately their 17's are not wide enough for mine http://nankangtyres.com.au/tyre/ar-1/
Have to say that my present Hoosiers are doing well, they are wearing very evenly across the tread with the shoulders holding up nicely, better than any other tyre I've tried. The other thing with Hoosiers is their sizing, plenty of 17" choice in 40 series which keeps the width up and the diameter down to help clear the guards. EG the 245/40 Hoosier is 622mm dia, 235/45 Hankook Z221 is 644, the difference allows me to use the wider 245's on the front, comparable Hoosier rears would be 275/40 only 648 dia.
I'm talking sprints where there is time to warm the tyres up, not time attack.
The Nankangs are brand new. I'm sure there'll be more sizes to come.
Of course you're not talking time attack when you mention Hoosier. Time attack have to use semis. Hoosiers aren't semis, they're 2 groove 'cheater slicks'. The latest ones aren't even 2 groovers, just a few broken dashes. Not semis by any stretch of the imagination.
The Nankangs could turn out to be good going on the Hankook success story. Price them cheaply to get them out there and let word of mouth do the rest then when they get popular stick the price up.
Tried them yet Harry? C'mon, get a move on.
  • 4 weeks later...
Tried the Nankangs out last week. Ran a best of 60.3 but that was not really representative of their potential - the admin people listed me as entering a Toyota Starlet instead of the Soarer that has been in their database for years, so I got put in a slow group with cars running over 15sec per lap slower!!! That's alot on a 60sec lap. I lapped that car twice in one session... As a result, I was only getting one or two clean laps each session to set a time.
Comparison to other tyres I've used - no car changes:
235 Hankook Z221 soft C70 compound 59.8
265 Nankang AR1 60.3
245 Nitto NT01 61.3
The rear doesn't stay quite as attached as the Hankooks did on the fast turn onto the front straight. Mid corner to exit they start letting go just slightly. Other than that they feel good. They should be a bit closer to the Hankook softs than those times were, but I don't think they're quite a match for them. That's still an awesome result for a tyre that's $209 per corner, compared to arguably the fastest tyre available!
Wear was very good. The only question mark over them is a strange circumferential line that's appeared around the center of each tyre - it's not quite straight. I don't know what it is. It runs the wrong way to be a tread splice. It's not from contact with the body as it's on all 4 tyres, and there's nothing to hit in the rear wheel wells. there's definite contact being made on the body in the front right - you can hear it in the left hander "Hungry" corner.
Edited by hrd-hr30
  • Like 3
I wonder how the NT01 in the same size would square up to the Nangers.
From what I'm seeing they perform well for you, but the adult in me is telling me to never buy Nankangs again because I'm not 18 anymore.
  • Like 1
Pretty keen to try the nankang ar1s to be honest quite cheap.Might give them ago next round of tyres im only on kenda kr20a and nakang ns20r at the moment so would expect large improvement
I'd never buy NT01s again! Better off buying RSRs.
That's a strange result for RSR v NT01... Normally not that far off the pace of NT01, which is pretty god for a non R comp, alot cheaper, road legal etc
First I've heard of RSR delaminating too. Tread splice opening yeah, but delaminating?
Edited by hrd-hr30
When I reported it to federal they considered it delaminating. We are probably talking about the same thing here.
I don't think it's strange at all. Rsr lasted maybe 2/3 hot laps and then greased over, Nt01 I could go harder and get about 5 hot laps before they overheated.
But nt01 is still only a introductory semi whereas rsr is very much a street tyre.
Why would you never buy nt01 again?
1. They're the slowest semi money can buy.
2. They're not road legal so you can't even legally drive to the track on them which is a PITA.
3. They're not CAMS approved for production car classes.
You're better of doing very similar times on street tyres, or buying literally any other semi (other than R888 :P)
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
