I've got them on 9.5s on the rear, and wouldn't call them stretched.
265s would be better for a 10" wheel, but these are cheap and basicaly full life left in them....
If only i hadnt just purchased a house :( Ill just run the RSR and learn to drive haha
Yokie AD08R's. Anyone know anything about them?
I used them on my old green Gts-t. Managed to match my RE55 time on short track in a high powered rwd skyline so they grip like crazy for what they are (a few suspension changes at the same time so that would have helped)... Not a semi by any stretch but you wouldn't lose time a whole lot of time compared (maybe 1.5sec slower)
Hey guys I'm going to be using the ku36 kuhmos as steer tyres on the drifter just wonderig if anyone's had experience with them, I think they are more of a sticky stret tyre than a race compound, I'm restricted to 205/50/15 in size, main reason I wanted stickier tyres on the front is to reduce understeer
Are you looking for a good street tyre, or a semi slick for circuit use. They are a good street tyre.
If you are after a semi slick the 15" rim will limit you, but it also suggests you have a light car. Look into Toyo 888 and Kumho v70a. They will be nice and cheap in those sizes too
Sorry forgot to say what car it is, it's a s13 Silvia , fully stripped and fitted with an rb25 , i can't see it weighing over 1100kg.
It's purely for drifting and I only want them on the front , was hoping that because they are a street semi they might last me longer than a race compound, also there design allows for use in damp conditions.
My main concern is weather I should have stuck to 17's and weather a 235 or 245 would have provide a lot more grip on the front , for the past year I've just been using cheap tyres like durun and sunny 235/45/17 as steer tyres, hoping that a reduction is size will balance out with the quality upgrade of tyre?
Best bang for buck Druncan ?
Haven't bought a set for a while, and last time I did the Federals were definitely the thing to have for the money. But I see Harry's warning that they have changed for the worst since.
I'd probably go Kumho V70A again, they worked well and didn't require me to sell drugs to fund them like yokos or dunlop.
  • 3 months later...
Anyone tried the BFGoodrich g-Force R1?
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+R1
It's not far off a full semi and they are pretty cheap. what do you guys think?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
