Anyone tried the BFGoodrich g-Force R1?
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+R1
It's not far off a full semi and they are pretty cheap. what do you guys think?
I think they're very soft. Should be good for hillclimbs if you're in a class that allows slicks.
Consensus is that R888s suck on GTRs, but are ok for light cars. I have R888s at the moment, after using Fed RSRs. Although there was some months in between the last RSR session and the first R888 session, they dont seem that much different (and they should be since S spec to R spec)
Ill be looking to go for something decent this year as will actually be doing some track work finally!
Running RSRs at the moment and they are good on tight tracks but as soon as i went on SMSP GP Circuit they were gone after a few laps! (Fronts)
I just got a set of AD08Rs in 285/30R18s for the R33 GTR from Traction too. In fact probably my 3rd set of tyres from there...
The AD08 was good so looking forward to trying these out... however I did run Hankook Z221s are they were amazing... for 2 track days then they went downhill.
I cannot believe that they still make wheels small enough to put a 195/50/15 on.
We have been very happy with the performance of Kumho V70a's on our R33 to the point that we have just purchased another set in 255/45/17 and 275/40/17 - just what you need for the MX5.
Hey Chubbs I have found some for you for $225 each at International Tyre Trader
Here is the page that they are on http://www.tyretrader.com.au/index.php?route=product/search&filter_tyrewidth=195&filter_tyreratio=50&filter_tyrediameter=15&sort=pd.name
At that price you would have to check the build date because they sound cheap
Where did you get them? How much for the 255s?
I have Falken RT615s on My 34 rims and hate them very very much, horrible tyre, I have AD08s in 265/35/18 on my 32 and love them, I have just put RS-3 in 275/35/19 on my 34 and am yet to see how they go, picked up a set of Z221s this mourning in 265/35/18 and have run out of rims :(
Didn't want to read the Z221s go off so quick, bugger
I picked them up from a guy who ran them on a Silvia in Time Attack - so even though they were on a high horsepower car they had not had a lot of use or heat cycles.
  • 2 months later...
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
