  • Replies 171
Yes, it just means that we will run it under our CAMS insurance as an official club event. Kinda like public liabilty insurance really.
Just means the poor exec who runs the cruise won't lose his or her house if some dumbshit runs into a ditch and decides to sue the organisers!
Hopefully riding shotgun for this one as the car is not finished..... :blush:
Just a quick mention, the roads at the moment in the Hunter Valley are rough as guts due to the roadworks and also just due to the poor weather etc.... Can you PM me the actual road we will be traveling and ill scout it and make sure its sweet as i am up there for work pretty often :thumbsup: (I work around the wineries so its no problem to check)
Good on you Matt!
Good on you Matt!
I'm not that far away from the finishing end and would be happy to cruise around and double check the road and report any issues, the organisers do a great job with these events and if i can help in anyway i am more than happy :D
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
