Hi All,
Has anyone had any experience with this turbo on their RB26DETT? I am wanting to know roughly when will full boost kick in by and peak HP with the following Mods:
Tomei Pon Cams
3" HKS Exhaust
98Octane Fuel
I have searched other websites but can only find info for Supra (4500rpm with 1.06 rear housing), Subarus and other makes, if anyone can help I will greate appreciate it. I have a rough indication from these other sources but if anyone has first hand experience it would be better!
I'm currently running GT2860-5 with (347 kw, 816.9 ft lp @ 20 psi at4w) I want abit more response and power am I making the right move?
https://www.sau.com.au/forums/topic/395035-gtx3582r-82-rear-housing/
Thanks for the info. I got Mine's Cam Gears which I forgot to add. Full Boost @ 4900rpm. 20PSI is what my tuner says its safe I don't want to push anymore then that on 98octane. Will I require upgrade fuel setup if I run 20psi on the GTX? currently running an intank SARD fuel pump.
Edited by fi5h
i have a 3540/3582r (gt tho not gtx) and on my 25 im making 20 psi at around 4300, factory cams and cam gears, with the gtr+cams+cam gears+gtx i would put yours at arounf 3500 maybe less.
If you going to run the same power then the fuel system you have will be fine, i dont think you will get much more out of it with a .8 rear on 98 pulp, if you went E85 you will need a bigger fuel fuel system but would probably get close to 400 if the .8 rear will flow enough.
GTX35R with 0.82 rear housing on my RB2530 hits full boost (24psi) at around 4400rpm
some of the results for the GTX shows its not as responsive as first thought but the real gains over the GT35R are above 25psi
3500?? No chance.
Just because its a 26 doesnt mean it makes it more responsive. 4100rpm is lowest I have seen for 20psi.
3500?? No chance.
And what about the cams and cam gears? there only good for 300 rpm lower on a 26 compared to a stock 25?
Thanks for your response guys. At the moment I'm tossing between the GTX3582R or E85 my current setup - both I think will improve response but I think with e85 I'll need to upgrade fuel setup? Tuner says I'll hit nearly 400kw @ 26psi with eflex tune. What do you guys think?
I think your going to need at least a full 3.5inch exhuast system and bigger injectors if u want E85.... alot bigger
Your gonna need a bigger fuel system in reguards to fuel pumps and probably a surge tank
you should crack 400 with E85 with -5s if u sort out ur feul and exhaust system...
Thanks Joe, Yes Injectors is a must just not so keen on 2 x fuel pumps and surge tank in the boot. mmm leaning towards the GTX option as its less work that needs to be done. If I can hit full boost by low 4k rpm I'll be pretty happy. .82 rear housing should do Nicely I think. 350-360kw is plenty for me right now lol. Keep the comments coming guys, you guys are helping alot.
My Twin setup might be up for grabs soon ^^
I would think changing to a single turbo set up would be a lot more work than just getting a bigger fuel pump.
What ever you do if you want more power you will need a 3.5 to 4in exhaust ( I don't think you ve said what size it is now).
Why can't you turn up the boost?
I have a GT3540 on my RB30 and so far it is only tuned to 15psi but even with a .63 ar it only hits 14psi at 3,500 and holds full boost from 4000.
I would expect you would get best response and power with a single grunty in tank pump and your twins..., make sure you have a big enough exhaust and turn up the boost until it makes no more power.
For still more power go E85 - your injectors should be fine and a big single pump might get you to over 400kw or else 2 in tank wouln't be too hard.
I get the impression that you are dying to ditch the twins for a single turbo. If that's what you will make you happy do it regardless!
700cc injectors on -5's running E85?!!!! from results ive seen i really dont think 700s are goin to even get close to cutting it
Id be getting some ID injectors... actually thats exactly what ill be doing because my 800s wont cut it and ill be chasing the 450rwkw mark
You may be right on that. There seems to be a wide variation on how much power people can get from a given size of injectors on E85 (or to put it another way different duty cycles for the same power output although not many people post up their duty cycle)..
To the OP: had a look through the upgrade results at the top and people with your turbos and 700 injectors but with a bigger intank pump (Nismo or Denso) and 3.5 exhaust system have made 381kw @ 24 psi and another 413kw at 25psi both on pump98.
That exhaust is killing you.. 3inch is too small for what ur chasing
ideally if i was you id be getting 3inch dumps, 3 inch front pipes with a 4 inch "high flow cat" and have the rest as 4 inch
keep the 5s i reckon as well.. therese plenty more power in them
Nismo intake will be fine for pulp, though if u want to run E85 id have that in tank pump feeding a surge tank that would have a couple of 040's feeding ur rail :thumbsup:
I'm more after response then outright power, I'm happy with the power atm just want it to come on sooner (of course making power will be a bonus :D) . Hrmm so you think getting a bigger exhaust system will help in response? I would of thought it would of been the opposite? Correct me if I'm wrong please.
Here are my mods:
R33 Block
-N1 Crank
-Forge Pistons
-Forge Rods
-Race Bearings
-Head & MainStuds
-N1 water and oil pumps
Garrett 2860-5
HKS dump pipes and front pipes
Hi flow cat
HKS Hi Power Silent Exhaust (According to their website its is 95mm 3.7")
Tomei camshafts
Mine's adjustable cam gears
Sard intank Fuel pump
SARD Fuel Rail + Fuel Pressure Regulator
SARD 700cc Fuel Injectors
Haltech Platinum PRO
110mm thick intercooler
HKS intercooler hard pipe kit
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
