I currently have an R34 gtr with some 18x10 +12 lmgt4 copies pictured below. Im consdiering some 18x10.5 work meister S1 3 pieces in an offset of my choice (thinking +5 or +8 maybe. Just wondering on peoples thoughts on how these would go with my car. The colours I would look at is silver with polished lip or black centre with polished lip. I wuold be getting the R disk which is deep dish. The car will be getting nismo side skirts, rear pods, z tune front bar and carbon wing blade shortly.
Even if there are any photoshop gurus that could help.
https://www.sau.com.au/forums/topic/395036-r34-gtr-with-work-meisters-s1/
  • Replies 61
Posted Images
Yes do it.
If you do go +5 or something, i'd love to try them on my car :D
10.5 +12 just doesn't cut it.
These are ssr but similar enough to give idea:
Someone has them for sale on here.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=382594
No do not do it. LMGT4's on a R34 GTR look great...do not change the look.
They aren't legit LMGT4s.
Black centre with polished lip, do it! I reckon it would look sweet if you did the side skirt extensions / rear pods in carbon fibre too (like Terry's white N1)
Yes do it.
http://www.skylinesa...ttach_id=382594
Woah, that car looks hot! Got any more pics/link to for sale thread for wheels?
Cheers
I think 18" will look to small against the car. Might have to go 19s lol
Also looked at the sizing chart and the only way to do a +5 offset is with an 11" wide rim, I wouldnt like to stretch 265s that far lol.
adamskill...its called having a job and working hard, im just reaping my rewards
just be happy with owning a 34 gtr you ass hole.
This ^^
Why don't you look into other slightly more original wheels? Meisters and SSR SP1's are so common and boring now... but of course all the little fanboys will have a reply to this
No, you can run +3 and +6 on rear and front respectivelly on 11", with unrolled guards and quite lowered with 275's, no issues.
This ^^
probably cos they look hawt...
jus sayin
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
