I'd be interested in one of those lips if there's a group buy ! What size / profile are most running on 19 s by 10.5 I'm thinking 265/35 ??
275/30/19 for me.
265 will have a bit of stretch.
If I were to purchase, i'd go 285 if I could afford :)
  • Replies 61
Posted Images
Go the Meisters mate !
Who ever says there "too common" firstly how many R34 GTR's do you see on the road, not including pictures over an internet board???
How many of those had Meisters on them ???
Point proven.
sorry to hijack, but re: the bootlip spoiler, you lose the middle brake light yes?
I was thinking about this the other day.
Does it then make the car illegal? Due to not having the third/centre light?
btw, there is a sponsor on here that does work meisters cheap occasionally. 18"/19" any width and offset you want.
  • 1 month later...
Change those copies out asap had this happen to one of the copies i had on my evo .
then had a present turn up for the gtr ! So now i can show you how they look with black centres once i get tyres fitted .
19x10.5 +12 had to wait for them to be made got them through JDM Concept on here great deal check here for price http://www.skylinesa...ll-29-feb-2012/
Would like to think if i had a better quality wheel this might not have happened so changed then to rpf1s and they look amazing !
Will get photos of the Meisters fitted once i decide on tyres (size/brand?) Am thinking Ku36s as i just fitted these to the evo and am liking them so far ???
LOL the reason I am looking for a change is the matte black wheels are hard to see
That's true...
Capturing the right lighting and angle takes a bit of patience - although these are satin.
At a slightly different angle, the spoke detail gets lost.
  • 1 month later...
I have the same problem right now. Are the r34 GTR and R33 GTR have the same size rear fender size. Can the wheels from that white R34 GTR fit on a R33 GTR?
I would like to use 19x10.5 at +12 offset all round with 285/75R19 all round. The car has coil overs and standard Brembo brakes. I really like the staggered look and would really like to see some more pics of a R33 GTR on some work wheels.
What do you guys think would give me the best looking setup I like that drift look with allot of lip if possible with out compromising tire size. Thanks mate.
  • 3 months later...
Mmmm looks awesome. Better photos asap please :D with some sun.
I want 18x11s but the problem is with the chrome lip, it makes the wheels look really small, so maybe 19 is the way to go.
Yeah sorry for the iPhone pics have better ones on my dslr but my computer died will get them up asap ! 19s look so small on a 34 I know you can fix this by going super low (I won't go lower) 20s would look good but it's not a show car it's meant to be drivin :) wish I had have went 285s would have filled the guards out more but didn't want scrubbing issues 275s no issues at all :)
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
