I'd be interested in one of those lips if there's a group buy ! What size / profile are most running on 19 s by 10.5 I'm thinking 265/35 ??
275/30/19 for me.
265 will have a bit of stretch.
If I were to purchase, i'd go 285 if I could afford :)
  • Replies 61
Posted Images
Go the Meisters mate !
Who ever says there "too common" firstly how many R34 GTR's do you see on the road, not including pictures over an internet board???
How many of those had Meisters on them ???
Point proven.
sorry to hijack, but re: the bootlip spoiler, you lose the middle brake light yes?
I was thinking about this the other day.
Does it then make the car illegal? Due to not having the third/centre light?
btw, there is a sponsor on here that does work meisters cheap occasionally. 18"/19" any width and offset you want.
  • 1 month later...
Change those copies out asap had this happen to one of the copies i had on my evo .
then had a present turn up for the gtr ! So now i can show you how they look with black centres once i get tyres fitted .
19x10.5 +12 had to wait for them to be made got them through JDM Concept on here great deal check here for price http://www.skylinesa...ll-29-feb-2012/
Would like to think if i had a better quality wheel this might not have happened so changed then to rpf1s and they look amazing !
Will get photos of the Meisters fitted once i decide on tyres (size/brand?) Am thinking Ku36s as i just fitted these to the evo and am liking them so far ???
LOL the reason I am looking for a change is the matte black wheels are hard to see
That's true...
Capturing the right lighting and angle takes a bit of patience - although these are satin.
At a slightly different angle, the spoke detail gets lost.
  • 1 month later...
I have the same problem right now. Are the r34 GTR and R33 GTR have the same size rear fender size. Can the wheels from that white R34 GTR fit on a R33 GTR?
I would like to use 19x10.5 at +12 offset all round with 285/75R19 all round. The car has coil overs and standard Brembo brakes. I really like the staggered look and would really like to see some more pics of a R33 GTR on some work wheels.
What do you guys think would give me the best looking setup I like that drift look with allot of lip if possible with out compromising tire size. Thanks mate.
  • 3 months later...
Mmmm looks awesome. Better photos asap please :D with some sun.
I want 18x11s but the problem is with the chrome lip, it makes the wheels look really small, so maybe 19 is the way to go.
Yeah sorry for the iPhone pics have better ones on my dslr but my computer died will get them up asap ! 19s look so small on a 34 I know you can fix this by going super low (I won't go lower) 20s would look good but it's not a show car it's meant to be drivin :) wish I had have went 285s would have filled the guards out more but didn't want scrubbing issues 275s no issues at all :)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
