Had to get a noise test done last week, was 92 but have to be 90 or under, to pass the guy made up a 2.5" rear section with some triple flow 2.5" muffler, as soon as i passed i put the old one back on coz the 2.5 looked and sounded poo.
I was thinking about just using a hot dog just behind the cat, will this cut the db enough to make it legal, was told by a mate that an 18" one on his datsun dropped it 10db, hard to beleive since this red back 2.5 i had put on only dropped it 7 db, also will it be more of a benefit to put it in front/behind/in between the mufflers i already have?
Im looking to cut out 4-5db (or more if i can) without losing power.
https://www.sau.com.au/forums/topic/395071-hot-dog-muffler-for-dropping-4db/
  • Replies 46
FYI in car audio type noise measurement (SPL), at the 90db mark every additional 3db is considered to be 'twice' as loud. So 4db is a pretty decent drop, get a muffler as a hot dog will just tone it down a little but probably still read similar.
I have a straight through varex with a hotdog in middle, 3 inch, 100 db open, 77 shut. magical. And my engineer signed off on it. Just dont use wot when closed or bad things will happen. that is unless you always want it quiet
Highly unlikely a hotdog will get you anymore than 1-2db in a proper test.
Need a stock exhaust or a welded in silencer at the rear
In normal 3" form my exhaust did 92, with 2.5" pipe and muffler behind the diff it did 85, that tells me that there is ways to make it legal without needing to weld shit in and resort to using a factory exhaust, what was the phrase i saw you use the other day "smart modding" with the right bits i will get a legal exhaust that will flow the 250rwkw i have and the 300 i will get after a tune.
The hard part is making it height legal and still look good, that will be my next task.
And if you have to do a db test they will probably tell you to change as its not allowed to be adjustable, does not matter what the engineer has signed off on.
Brett what is your current exhaust set up - ie. centre muffler(s) / rear mufflers, diameter and length of mufflers
a big fck off centre muffler is the solution
there's some talk of Borla mufflers here
http://www.skylinesaustralia.com/forums/topic/394860-tomei-extreme-ti-cat-back-exhaust-system/
Edited by Ronin 09
Funny that, even though plenty of cars have variable mufflers from the factory, even taragos
Get a hotdog, you'd be surprised at what they can do. My system has only the cat, a hotdog and the Varex which is effectively a straight through pipe in open mode, which nets about 100db. Surely without the hotdog it's just a straight out exhaust, which would be heaps over 100db...
Same!
When I went for my test the guy said Varex probably wouldn't be legal, I said my exhaust doesn't sound that loud when it's open so if it passes on open can you clear it? He said he might be able to do that, but open came back as 100db lol. It sure didn't sound like 100db.
The legal limit is ridiculous though, the standard system is only just legal and it's quiet as shit.
16-18" x 12" x 8" rear muffler
that will get your 3" exhaust legal easily if you have a decent middle muffler.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
