And if you have to do a db test they will probably tell you to change as its not allowed to be adjustable, does not matter what the engineer has signed off on.
Cant. As long as they dont hear it they have nothing to stand on. Especially when the controller cant be found :-)
Also should add i also have a cat. a highflow shit one that probably does less than nothing.
  • Replies 46
The EPA down here are not idiots.
They are well aware of Varex mufflers. If you have one, you fail.
1.buy varex
2.get old rusty muffler from exhaust shop
3.put rusty case over varex
4. Profit??
I have no interest in dodging any thing up, I want it 100% legal so I don't have to worry about it if I have to get it tested.
16-18" x 12" x 8" rear muffler
that will get your 3" exhaust legal easily if you have a decent middle muffler.
I didn't miss your post titan, I will measure the ones that are in there and see if there the same size, put on hold for now tho as I think I f**ked my clutch on the weekend so I have to pull the box out and see what the problem is, atm I just wanna burn the f**ker!
Welcome to nissan ownership.
I've had it for five years now, lately tho 5 things have f**ked up one after the other, most minor but the most it has been running fine for in between each is 1 week, now I have to pull the box out again to check my new clutch
the biggest issue is getting it quiet at idle/low revs with big pipes, easier with 3" than 3.5" or 4" as there isnt enough exhaust gas flowing through to make the mufflers work their best
you can stick huge mufflers in it like i/you have done (mine is 4" -> 3.5") and you are fine at revs, but dont pass the idle test (which isnt applicable in the ACT (or NSW afaik) but is part of the VIC test) as that is the part of the test i assume you are failing on? or are you failing at revs?
No idle test, it has to be 90db or lower at 4800rpm, no other tests for noise are done.
Doesnt matter, maybe in vic its different but. In NSW, my engineer said its tested shut, driven shut, there is nothing they can say. Even if they know its a varex. He said there is no difference in me testing it with that or having a quiet pipe then swapping it at home. Except how fast it can be done. He instructed me when harassed about it to take it to the top as he told others who succeeded.
Thats NSW laws though they smash you's alot harder there.
what about adjusting the idle speed lower? would that help the idle test..
i have a 3 1/2inch system with restrictor in muffler but will put a 4inch nur spec muffler on soon, so ill be in the same boat, might be 100db so would 2 big 3 1/2 inch mufflers do the job?
hmm have to wait and see, i think in queensland this isnt so much a problem..
Who is your engineer in NSW? PM me if you don't want to post here. I have done the ring around and there's nobody I
found that would test a variable exhaust at anything other than fully open.
To the OP: it's super unlikely that you'll get done for 92dB vs 90dB. You can get that much variation from temperature and surroundings on the day (lower temp = louder; harder surroundings = louder). If you pass the d1ckhead test you could probably get away with 95dB :P Resist the temptation to tell Mr. Po Po to jam it, and you will avoid being in a world of hurt.
Cheers,
SW
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
