My vote is still for the KU36 as a great value for money proposition. They stick like shit to a blanket in the dry. They don't grip quite as well until you get a little heat in them, and this more so in the damp, but I have never had cause to worry about how well they hold on in the wet, even in streaming water, even with only 1mm of tread depth left, once they are warm. Which doesn't take long.
  • Replies 43
I'm running -3.5 front and -2 rear camber, Hankook ventus RS 3, 255/40 17.
I have no understeer on the street wet or dry.
Cheap hard tyres are fine for shopping trolleys or doing skids.
Tyres cost $125 a piece from tire rack.$730 delivered.
Why do people buy sporty style cars and then go pov on the most important part.
^^ This man speaks the truth!
they are okay for the street and daily driving, i haven't pushed them too hard yet but i'd imagine they would be alrite in the dry but loose grip when it gets too hot (sorta like how the proxes 4 were after 4laps @ wakie)
does anyone know of any places that stock hankook ventus in NSW at a decent price?
from tirerack, it equals toa bout $250 a tyre after shipping so anythign around that range, i'd be happy to pay.
I haven't had problems with the 595SS over the time I've used them. In a previous car (a turbo FWD) they were a lot better than some pirellis that cost me a lot more and performed worse. Not hard to control in the wet at all.
At the moment I have 595 RSR's on the front of my XR6T and they never give me an issue either even when its pi$$ing down. There's gotta be something else up with people that are having massive issues, whether its driving style or car setup or something else again. Not saying that better tyres wouldnt help, but considering a very significant percentage of cars on the road (id imagine at least 75+) run worse tyres and that you dont see people spinning out or crashing at every corner in the wet, then maybe it's not just the rubber.
they go to shit after 4 track days because they arent the sort of tyres that are ideal for the track
i wouldnt have though tyre compound would have a bearing on wet performance, the tread pattern is what gives a tyre wet performance
Tread pattern and compound both effect wet performance, a hard tyre will not "blend into the surface" (for want of a better phrase).
I run Toyo T1R's on my GTR and street GTS-T because I want good grip in both wet and dry conditions and as I do only a small number of k's in these cars the price of $1400 for a set is justified.
On our track GTS-T we run Federal 595 SS as our street tyres because we have semi's for track use. With the more agressive wheel alignment and suspension components you cannot justify the cost of high performance street tyres and with their softer compounds they would only have a short life span. The Federals do this job well but they are nothing like the Toyo T1R;s to drive on.
  • 6 months later...
Pump your tyres up to 40psi.
Get wheel alignment done. Ask for pre and post alignment printout.
Mabey a obvious question to some. But.....
What determines the tyre pressure? Ie size? would a 235/40/18 be different to 235/40/19, Rim width? car weight?
Doing a bit of reading now, Seems people are doing there own calcs based on car weight.
R33 GTS4- My door car read 32 PSI max - thats what i always had them. Wheels were some jap 15" rubbish.
Edited by sydking
The best tyre pressure to use is that which gives the best result. This is easy to work out. You fang the car through some corners that you know and assess how it feels and how well it goes/grips. Then you add a few psi. Refang. More psi. Refang. It will have a region where it feels best and then it will probably start feeling bad. The middle of the "feels best" region is most likely your best tyre pressure. For performance anyway.
Done on a track you can time the car and you can measure the tyre surface temperature as well. This will allow you to work it out down to 1 psi accuracy, although you might find that you need different pressures in different tyres (on the same track) and different pressures between tracks. That's just because different tracks put more or less load on different tyres relative to each other.
In general, on modern radials, you will get OK performance at 32 psi and tyre life will be fine. If you flog the car hard through the hills though, you will probably experience the tyres getting hot if you start at such a low pressure. So most often you'll end up needing to run in the mid 30s. Even in the same size, some tyres have stiffer sidewalls and so will need less pressure. Others will need a few extra psi. All worked out by experimentation. Anyone who tries to do it by calculation has their head stuck up their arse and needs to get off the computer and out into the real world.
KU31 are quite possibly better than the 595SS in the wet. That wouldn't be hard - the KU31 has a fairly normal tread pattern and the 595SS is pretty poor in the wet. I would still expect the 595SS to be better in the dry than a KU36, but of course, everyone's mileage will vary.
why would you expect the 595ss to be better then the Ku36, WHen the closest comparrison to the 36 is the RSR. Both should be miles ahead of the ss. or 31
    • Just don’t be silly enough to think it’ll never happen either
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
