S A U N S W - Texi, "the Original" @ Sutton Road
  • Replies 219
Dont know how you figured that out - BOV's are not cared about. Screamer and straight through exhausts are the big no no's
I figured venting to atmosphere included blow off valves that werent plumbed in but its a relief to hear i was wrong, in like flynn as soon as the money is in the bank, looks like we wont have the same problems with attendance the last track day had!
Small update, I have organised for this event to use a flying finish with lasers (similar to WSID) for timing. Each group has their run then those times will be uploaded to Natsoft throughout the day.
This does not increase the entry price.
cancel whatever other plans u have pezhead, event would be weird if your not there!
will have to wait till i get my rent from a flatmate till i can pay it, hope a fortnight from now still sees it with spots left..
update done.. to all those people 'thinking of entering' do it now or you may never get another chance.. If this doesnt fill it wont be coming back!
and before you ask if there are spots left we have 33..
its simon Cowell's dad. oh and lern to meme!
im 100% keen but dropping the gf's brand new ipad3 the other day means i cant afford it this pay ($330 to replace screen...figured just buy another one and use the smashed one myself) will keep me from paying for another 2 weeks. How are the numbers looking for this? oh and whats the history like with people going off and into the scrub? i have the ominous feeling the run off is less kind than wakefields?
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
