S A U N S W - Texi, "the Original" @ Sutton Road
List is updated
Might I just add there are still 25 spots left because all you "ill pay soon" people never eventuated.
We will all enjoy sutton road immensly with more runs than we can count because we sure as shit are not coming back with the lacklustre entry list so far of 19
  • Replies 219
Hi Mick, I got your entry and forwarded to Aggrodave tonight.
James, me too, it's a good event, but I guess the club exec can't keep running events if they don't get the entrants.
Anyone wondering about whether to try it or not....give it a go, you'll have a ball :D
hmm, unfortunately it is looking like I will have a saturday afternoon soccer game so I wont be able to make it, unless it gets changed to Sunday at the last minute. sucks cause I was looking forward to it :-(
Brendan here - I'm the mate with the Commodore sweefu spoke of earlier.
I am in for this, and will get the payment and entry form sorted sometime today.
Thank heaps for putting this event on! I've driven past this track twice everyday of the week for the last 4 years, great to be finally able to give it a crack!
Thanks Duncan,
I can't believe that there arent more ACT SAU'ers interested... Everyone down here knows how awesome that back track at Sutton Rd is and how rare it is to be able to get on and drive it! :(
Was thinking the exact same thing. I thought maybe they think it's the skidpan we have rented - but I've been pretty clear it's the track?!
What time is everyone leaving on friday to head down?
Also, do you exec fags want me to post up the event on Autocult>?
Go for it. You can do an event coverage type thing afterwards too if you want?!
I'll be there around 2pm at the motel
Wish I could join but I am to worried about my clutch at the moment.
I was wondering if you still needed people to stand on the corners I do that pretty well haha
Would be more then happy to chill out for the day and watch sweet cars rip it up.
The mg club have it booked for Sunday....
They used to do (still might, not sure) a quarterly event there on the skidpan, as far as I'm aware it was never the track though.
Yes we do actually! Thanks for that, come on the day :)
I'll probably be to busy driving to shoot/cover the day. Kory the skirt is busy playing soccer or some gay shit. I'll probably bring down my camera and take a few shots but doubt there'll be enough for a post. If there is I'll put something together :)
POST IS UP. LINK
Edited by MaTBoY
A few questions after watching that video linked from page 1 for the 200th time:
  • does that bloke get air over the crest at one point in the first half of the course?
  • is the course going to be set up exactly like it is in the video?
I'm keen to know if we are going to see enough straight road to get into 4th gear at serious speeds.
Forecast for Saturday is looking good! -2 over night...shiver me timbers!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
