Hey Guys,
I know you will say don't do it blah blah, but it's my car so Please help me out if you have any experience.
Iv'e ordered a sheet to do some interior parts there not individual stickers but a Whole sheet and cut it to shape, But what I was wondering, how would I Go about preping the interior plastics to hold the self adhesive sticker sheet (A Pillar, and the plastics around the gearstick, door handles etc?) Wax and grease remover? or what?
Thanks guys
https://www.sau.com.au/forums/topic/395144-sticker-bombing/
i'd imagine sand it back a bit, then give it a good clean and wipe down. might wanna check that though. i've got no experience with those big sheets. i dont see how'd they'd be any different to individual stickers. normal stickers should have no problem on a clean surface especially on the inside.
Edited by alex182
https://www.sau.com.au/forums/topic/395144-sticker-bombing/#findComment-6282636
It will depend on the surface you are applying it to, it says you have an R33 (on the left side thingy), if you are planning on doing your centre console/dash fascia etc... you will more than likely need to remove the factory rubbery paint. (metho and a scourer/rag will do this)
Once clean use Isopropyl alcohol (IPA), pretty sure this can be bought from most hardware/auto stores, to give it a final wipe down before applying the vinyl.
This was done using the above method.
https://www.sau.com.au/forums/topic/395144-sticker-bombing/#findComment-6283076
Scourer sounds abit dodge (not sure)? but their a thing called scotch tape it comes in diferent colours meaning diferent abrasive's then wax and grease it.
Give it a realy good wash if u have ever used interiour cleaners as its a bitch to stick stuff to
https://www.sau.com.au/forums/topic/395144-sticker-bombing/#findComment-6286412
I thought t about sticker bombing my whole R34 front bumper or the just the lower quartile, they look good in photos and video's such as stanceworks and hellflush and might serve in protecting paint work from rock chips but i dont know how it will turn out so putting that idea off.
https://www.sau.com.au/forums/topic/395144-sticker-bombing/#findComment-6286677
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
