Hello
I have a R32 GTS-T with these mods; twin front pipe, catback exhaust, fmic, pod and soon will put on a RB25 turbo. Looking at computers now. But until I buy a ecu and tune the car, with these mods when is the time to upgrade to a bigger fuel pump and injectors?
My guess is the second hand pump is exactly that 2nd hand.
For the price of a new pump these days $160-$200 direct replacement why going 2nd hand?
Also its the life source of the car without fuel you will lean out and do more damage then $200 for a pump
Why not, I got a s/h tomei and its brilliant
Thats different in a way. Its more than likely not that old.
But still i would definately prefer not to use 2nd hand fuel pumps.
I knew op was going to say a 2nd hand GTR pump.
With most things that run in fuel, once they are removed they dry up, seals swell etc etc.
since you guys are talking fuel pumps, whats the limit of power for walbro 255L/h and 555nismo's on pump98?:whistling:
Pretty sure thay nicked named them Walbro 500, as in 500HP.
Basically they are generally good to 300+ wkw in most applications. Ive seen so many cars putting that power figure out, and more with only a single in tank pump.
Cant comment on Nismos one.
I brought a genuine walbro for 130 they come around cheap sometimes keep an eye out. Dont buy second hand, its not worth it when your chasing power increases.
Heres a mean set-up my mates put in is R32.4, 1200HP SX pump to keep his 420wkw gtr fed :D
Edited by HYBR3D
Nismo will do 400rwkw
Walbro - anyone's guess. They are very hit and miss. Mine nosed over @ 270rwkw, others have run into issues at less, some have made more. Gamble you take really. Walbro's from their own information - don't like higher pressures like a Bosch/Nismo etc perform ok.
In engineering is a term called B.S.F.C
(Brake Specific Fuel Consumption)
You could use this caculator to give you an idea about fuel requirements for injectors and pump.
http://www.rceng.com/technical.aspx
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
