Hi everyone this is my first post here so it could be in the wrong catergory if so, sorry. so im currently looking at buying this r33 but mymaon problem is that the aircon hasen't been gassed since its been imported (approx 5 years ago) and i cant drive a car without the aircon so i plan on getting it regassed asap but i have been told by a friend of mine that i could be looking at up to $2000 to get the aircon working again because it hasent been used in so long, but another friend tells me nissans engage the aircon when in reverse to avoid this and then another friend tells me the o-rings should be fine because its all sealed up and therefore the o-rings cant dry out. So now im really confused and need your help. I have used the heater in the car and that seems to run fine if that makes any difference.
Appreciate any help given
Ps1Locybe
https://www.sau.com.au/forums/topic/395188-r33-aircon-re-gassing-help/
hey mate, if u r serious about buying that car, tell the owner youll take it IF he re gasses it and obviously it is working, get the money ready, go with him to the workshop to have it done so he knows your serious, on that basis im sure he would be happy to get it done. Also, make it clear if the thing doesnt work after it is regassed your not interested or somthing along those lines.
G luk.
Thanks Nathanau thats smart thinking, the owner of the car is my best mate so im not to worried, he is only selling it to me for $3500 so im not to fussy i am more or less just hoping to hear that nissans do indeed engage the aircon in reverse or that i should be able to get away with just a re-gas but im guessing its alot more complicated than that, im
Not mechanically minded hahahaha. I greatly appreciate your speedy reply Nathanau :)
Ps1Locybe
seriously dude, just get the yellow pages and find an aircon specialist in your area. call him. tell him what you just told us, and get an ACTUAL answer. it will take you 30 seconds, and then you will know for sure.
Even with a best buddy, still tell him that his $$$ is waiting for him when he comes back with the A/C working!
If I was your mate, that's what I'd do for a 'delicate flower' like you.
I only say that 'cause I have none. Hehe...
Almost positive it won't engage in reverse. Think that's a euro car spec. If the system is together and sealed up then it should just need a dryer(filter) then re-gas which should only be a few hundred bucks or so. Worst case if the compressor seals are leaking then you could prob get one from a member on here for 50 bucks if you look around. Unsure on cost of new compressor.
never heard about nissans engaging the aircon in reverse.
The N13 Pulsar my cousins had used to do that. Never heard of skylines doing it tho. Also, skylines have a pressure switch such that if there is not enough gas pressure in the system, it wont throw the magnetic clutch to engage the compressor.
OP - since it doesnt work, assume the compressor is stuffed pay the price you think the car is worth less the cost to supply and fit a new compressor, regas etc. $2000 seems reasonable once you include all the stuffing around.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
