Hello
I have a R32 GTS-T and I want to paint the Cas cover(the thing that covers cam gears and timing belt) and cam covers.
How do I do this? How do I remove the Cas cover? Do I have to undo the timing belt and things? If so I will leave it for a shop to do.
Should I primer everything?
Also can you paint piping and inter cooling piping?
Hello
I think you mean the timing cover, not the CAS cover. The CAS is the sensor that sits on the right hand side of the timing cover. It's quite simple to do, but you will need to check your timing before and after removing the timing cover as you have to take off the CAS. Easy if you know what you're doing, potentially dangerous if you don't.
Rocker covers are very simple, you just undo the bolts holding them down. Nothing tricky with that one. I suggest removing the PCV and masking up the breathers before prepping and painting. Primer isn't exactly necessary if you prep it all correctly otherwise, but I would still suggest priming it anyway. It certainly doesn't hurt to do so.
Piping and intercooler piping is also quite easy. If you have aftermarket stainless or aluminium piping, make sure you sand it back well and primer it as often they put a coating on it to protect the finish which will cause your paint to peel off. If you are painting the stock piping, make sure you clean it really well with wax and grease remover to ensure no oily residue from sitting in a 20+yr old engine bay ruins your finish.
Just prep prep prep prep prep and be patient with it and it will come out fine thumbsup.gif
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
