Eoi: Sake Brewery Tour, Tasting, Bbq, And Photos!
Ummm - guys!Let's make this the Venue for the 10th ANNIVERSARY of SAU - Cruise and SnS ???
Sounds like an awesome idea terry.
Sounds like this should be a spectacular day, Yes your right about the cheery blossoms Terry, they are on site and appear later on in the year, but would still look cool as they are now..Need to get idea's On the date best suited, and the day WILL BE A SUNDAY!
Later for the cherry blossoms to bloom for the anniversary would be good.
And on a sunday, im in like flinn.
In, the sooner the better, can always go back later on in the year.
This would also be good. Why have one cruise, when you can have 2.
Alright, Should be a great Day.. I do however suggest people Car pool Or get a Deso if they want to taste test our Products as they are Alchoholic!
I can be a deso....
So, terry, just give me your keys when you arrive, ha ha ha :cheers:
  • Replies 141
Posted Images
Juz this is great!
I'll try to get someone from the exec team to start working with you on it. But we are flat out right now getting ready for the track day and then we have Putty Rd and then AGM elections and Sutton. God we're a busy club!
So will need to see who I can round up to get this going with ya.
Guy's I don't want to sound rude or anything Lol, But everyone can put up dates etc but the Final one will come down to when we can do it at the brewery as We are always traveling to japan to meet up with the father company the Konishi brewery company, so bare with me with dates etc!
If that was aimed at my post, sorry, more of a joke than anything.
Don't know if anyone would really do the reverse putty.
Unless that's what you're after.
After all, you're the organiser.
So, do you have any prospective dates yet?
Sounds like it should be a good turn out.
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
