Kor'axis - those knobs are the only ones they make (im 99% sure) .. so no blue sorry.
Guilty - send me an email if your in... the sooner the better as we already have enough interest now to go ahead.. just waiting on payments to clear.
also, got prices on some other rice... Oil caps are $115, radiator caps $55 and fuel caps $80.
  • Replies 91
dave, the fuel caps/oil caps, are they the shitty old style ones or the new ones?
http://www.nismo-webdirect.jp/webdirect/im...013_shohin2.jpg
http://www.nismo-webdirect.jp/webdirect/im...011_shohin2.jpg
also, the fuel caps (at least the old model http://www.nismo-webdirect.jp/webdirect/im...010_shohin2.jpg) was just a "cover" that you use double sided tape to hold on to your oem fuel cap.
Are the new ones just "covers" or are they actual replacements?
Damn it! I just payed $105 for my side indicators 2 frikken weeks ago and they still haven't arrived.. :) (Not through Dave, through MSI)
But anyway, the Carbon Pillar Garnishes and Blank Key are lookin pretty good for me at the moment.
also, the fuel caps (at least the old model - was just a "cover" that you use double sided tape to hold on to your oem fuel cap.
The caps are the "shitty" old style ones :) . I didnt get a price on the others as I didnt think they would be popular (i like the old style). If you are interested I could get prices on the new ones 4 u. I am not sure if the new fuel cap is a cover, but by the looks of it your right about the old one... didnt notice that..
Guys, originally was going to do each type of part as a seperate order, but have heaps of interest with gear knobs, so will be placing order all together so the other guys who want winkers and keys etc dont have to wait as long. By the looks of it, this may continue for one more order, but if you dont want to miss out try and contact me asap as the order will be placed in around 10 days and need time for payments to clear etc....
Dave
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
