last minute calls for a Wakey track day with NSCC on this Sunday.
yeah its the day after the SAU one but if your hardcore like me you will just stay overnight and get back up in the morning ready for more!
heres a cut and paste from their thread
These are eagerly awaited days and payment into the account is your only guarantee of a spot
So get those names down and payments in to secure your spot
New Members are warmly invited to attend. Instruction from experienced drivers will be offered on the day
Note you will need a Cams L2S license (See www.cams.com.au ) you can also do it online, (refer to CAMS sticky) or purchase a yearly Wakefield license on the day which is about $50.00
You can hire a helmet at Wakefield $20 with a $50 deposit.
You will also need long pants, good closed shoes, a helmet and long sleeved shirt.
Bring your Numbers if you have them allocated or we will allocate one for you on the day.
Battery triangle and Fire extinguisher not required for the day.
NOTE: Scruitineering will be starting at 07:30am
Start Time 07:30 am
Drivers Briefing 08:30 am
First Session 09:00 am
Lunch 1:00 pm
Second Session 2:00pm
End of Day 4:00pm
Read the following FAQ's
Wakefield Park
http://www.nissansportscarclub.org/f...read.php?t=429
Track Day Basics
http://www.nissansportscarclub.org/f...read.php?t=565
member ship is fifty bucks i think but you dont need to join, probably just a bit extra on top of the normal fee.
thread is here
http://www.nissansportscarclub.org/forum/showthread.php?t=5101
https://www.sau.com.au/forums/topic/395363-track-day-wakefield-25th-march/
Aha mark the Valdez holds its oil inside. Your car is more like a Bp oil rig in the gulf of Mexico :P
http://en.m.wikipedia.org/wiki/Exxon_Valdez_oil_spill
This is what I'm talking about Willis.
And it was a boat too, just like the 33.
Which is slightly lighter with no carpet and "most" of the deadener removed (note: it take more than 5kg of dry ice pellets to do a 33, 10kg would have been good)
how much weight do u think it removed? how loud is it now?
It is a bit louder but I use the nissan floor mats which keeps the noise down a bit, but then I like noisy cars anyway, listening to the fuel pump, clutch, diff, small rocks kicking around inside the guards and stuff is cool.
Weight wise it would be lucky to be 8 kg all up, the heater core leaked so the carpet was kaput so had to come out anyway, the deadener I removed was more for something to do experiment/ fun/bored wise.
If I can get the car going without spitting oil Im going to strip out as much as I can, Ill still be keeping the A/C though.
The AC and all the fan shit is probably the heaviest stuff you can take out... LOL
Your other major weight area is to re-wire the whole freaking car.
Otherwise... Don't bother really.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
