I'm looking to get a dyno tune shortly in my S2 RS4S, but my tuner (Unigroup) only has RWD dyno
I've read plenty of people say 'just drop the front driveshaft', but i have a couple of questions regarding this.
Quick inspection suggests that the transaxle has a yoke and the front diff has the flange. That suggests i'd need to unbolt at the front but wouldn't that mean the shaft is still connected to the transaxle and will spin freely?
Or do people actually remove the yoke as well? (wouldn't that spew fluid everywhere?)
Any input from people who have done this is appreciated
https://www.sau.com.au/forums/topic/395416-dropping-front-shaft-in-c34/
When people say "just drop the front driveshaft" they make it sound like a ten minute job but in reality it will take quite a bit longer so do it well in advance of the day. You need to get the car up in the air so if you haven't got ramps and axle stands you will have to jack up one end at a time and securely block it so that it can't fall on you . You'll need a couple of good quality ring and open enders (can't remember if they are 12 13 or 14mm). Squirt the nuts with CRC or suchlike and then go and have a cup of tea. When you come back bring a hammer as you may need it! If you have a clutch remove the slave cylinder as it tends to get in the way. When you have the shaft out and the car on the ground go to the fusebox in the engine bay and you will see which is the AWD or 4WD fuse ( I think its green) - take it out and put it somewhere safe. You are ok to drive round like this.
The other method of getting it in to 2wd by pulling the plug inside the driver's kick panel works too but for the dyno probably as well to pull the driveshaft.
I got baulked by the slip in yolk on the transfer case also.
Good to know it doesn't leak the oil out but how do you keep the road smeg (sand, water, general crap i run over) from finding its way in to the hole?
Edit: Grey tape would probably do it i suppose?
Edited by shane344
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
