Over the coming year builing upto getting my full lisence I wall be slowly saving my pretty Pennies to do a full M35 stagea nose on a V35 skyline to make a MV35 stagline.
Engine, gearbox, body... Everything.
So i there you are parting with some OEM stagea parts let me know on this or PM me.
VQ25DET turbo and 5AT box
Looking for preferably white body parts.
If there is anything I should look out for in stageas also let me know
https://www.sau.com.au/forums/topic/395458-mv35-stagline/
Would look pretty cool with a series 2 (PM35 - 2005+) front.
There are bonnets on Yahoo every now and then (make sure it is the right one), front bars are always on there and usually cheap and there are a number of HID headlights on there now that are cheap too. I don't know if the front quarter panels will just bolt on, but they'd be damn close.
Just make sure it is a 2005+ Stagea front :)
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6283717
No staying RWD. I can either get a whole front cut which engine, tranny, panels and all for about 3k+ or buy individual..... Will deffo nead HiDs because I have them on the skyline now.
Would love the axis autech kit
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6284219
Surely it would be better to just buy a half-cut? That way you don't have to search everywhere for silly little things like the wiring/relays you didn't get with the engine etc that hold up a build, and frustrate the hell out of you...
Has anyone built one of these before? Pics? Photochop? would love to see how the lines suit/don't suit... Just remembering that M35 with the R35 front: there were a few really awkward looking lines from some angles...
That said, I Like the M35 s2 front much better than most of the V35 fronts: looking forward to seeing the end result!
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6284986
Reason I ask is the 2.5dd has the same ecu plug, cams and sensors as the 25det. It may make your job easier, especially if you can get e85 and some turbo parts to drop on your current engine. Is there an e85 servo near you?
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6285245
That bottom pic is the face lift I did to my series 1.
Definitely looks much, much better except I didn't have the strip (and bracketing) that goes on the bonnet.
Pic in this thread: http://www.m35stagea.info/forum/viewtopic.php?f=23&t=122
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6286986
  • 1 month later...
Was going to buy a Toyota mark II and sell the skyline but I'm attached and it's a Toyota. So! The stagline project is going ahead with the commencement of my full liscence.
Just a couple of questions:
-My car being RWD and the VQ25DET and transmission being AWD will a NA VQ30/35 5 speed box bolt onto the VQ25DET?
-would it be cheaper buying a front cut with panels, engine, and all minus the box and buying that separate?
-is there any little niggles/faults/problems that arise that need to be addressed whilst the car is off the road?
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6363375
I have a variation of those blinker covers on my Skyline, I think the top pic is the same as mine. I also believe that they are a factory option, can somebody with FAST please confirm.
You can also source them on Yahoo/IM.
https://www.sau.com.au/forums/topic/395458-mv35-stagline/#findComment-6363404
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
