Mv35 Stagline
Is this the same car as the one sitting on enkei RPF1s that sits next door to the tile mob at warners bay
that thing looks insane?
Edited by tuckin7
Aero front bar, some simple skirts on the side and rear would top it off. Looks good though, In a whale like way lol
The way you damage front bars; an Aero front bar is just going to end in tears.
We aren't talking about me here, but about this beached az whale bro.
I don't know for some reason I liked it better with a black front bar.
But what do I know, I drive an emo
  • 3 weeks later...
Ok so havent updated in a while and some changes are happening to the stagline: First is a "new" VLSD out of a wrecked jap spec 350Z coupe $490 posted from japanese import spares to my door in newcastle, is going to be shimmed and replacing the 3.3 standard open diffs that sedans are graced with. Should be interesting to see how it goes. Has anyone here ever done it?
Also have a major exhaust leak at the moment. Hole roughly an inch wide and 5inches long. Solution is a midpipe from a V35 coupe. Same length but with a smaller muffler. Cant use 350Z as it is 6inches shorter. This with the straight pipes out the back will result in a nicer and deeper note (hopefully).
Also doing a general oil and filter change and transmission fluid change. Just a few things to get after that: M35 front reo bar, passenger weathershield, inner gaurds and under plastic and thats basically how its staying until july when it gets a new engine, box and other things too........
Edited by Howaitonaito
you drive an emo......... hope her daddy approves :mrt:
Edited by joshm35
  • 3 weeks later...
Had the car raised to goto panel beaters because some L plater hit it, not bad damage tho. So its 100mm ground clearance on R32 GTST stock wheels that just clear the brakes. Got the diff and coupe midpipe but its on hold until car gets fixed, then theyll be put in and it will be getting slammed yet again. Seat rails is what i wanna fix because tho the car is (was) slammed it still felt high and would love some super low rails, anywhere i can get some. Would like to keep factpry seats but not required.
Yeh bride super lows, but they won't fit the stock seat, you'll need something like euro 2's for comfort..
Speak to ARK design. They have good seats for cheap too with bride rails
And then compare pricing from this Ebayer http://stores.ebay.com.au/4x4-and-Performance-Online?_trksid=p4340.l2563
He's a Stagea owner & member on SAU.
Lol. Yeh Scott did that, it's only a matter of time until it starts to look out of place and then you'll change it. But yeh, euro 2 is very comfortable and very hugging. Good daily seat.
 Share
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
