I don't want to fit a modified engine, I want it stock to get it running right before he goes chasing the powerz. I won't be fitting the turbo heat shield anyway so it should only be a few hours work to drop the turbo.
I think Alex was just pointing out that the engines aren't the same, and I should be fitting a det ecu into the V35. It won't work mate, too many ecu's needing to communicate to each other. I would rather try and trick the DD ecu into thinking it has a DD engine connected to it still.
The engines are essentially the same. Not saying there won't be issues to tackle, but I am confident I can get it all running with the EMU connected.
I would love to go a built 5AT in the future but at this stage im keeping the 4AT. It works and thats all that matters. Like scotty said get it in and running stock and go from there.
Wish my tax would come back already. Im very impatient.
  • 3 weeks later...
Ok kids its getting close. The parts list so far is:
-VQ25DET motor.
-Factory Turbo.
-Scottys dump pipe.
-Valve body.
Just waiting on tax return for Greddy Emanage.
All this on a maccas salary.
*dances like mr bean*
#NoFace
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
