Hey josh...give him a break. We were all flatcappers or hard Parkers once upon a time. While marks a little bit of a smart arse at times I pretty sure most of its in misunderstood humour.
P.s plus I don't know whether his my kid yet...i had sexy time with this chick(I think....she was a little hairy) years ago and he does sort of look like a like me! A chick magnet! :P
furry muff
  • 1 month later...
Hey kids its been a while since ive updated this.
First of all i had a great time at the cruise. Craig and Theo did an awesome job. Hopefully i'll be able to keep up on the next one
Second of all i have sold all but one of the remaining V35 sedan parts with the bonnet left. All the funds will be going to "markneedsanemanage foundation" (feel free to donate) will busk if have to.
Thirdly the cam timing sensor can go EADC!
#NoFace
Edited by Howaitonaito
I'll do what I want with my farkin' lemons, you bloody young smartarse!
And it ain't calm, that's for sure!
Your memes are amazing, but it does make me wonder how you find time for anything else in life while searching for awesome memes
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
