That's why I asked - the bonnets shape around the headlight looks to be slightly different to the nm35 headlight itself
Pic for your reference although no bonnet, you can see where the "tabs" sit in relation to an NM headlight.
less gears in an auto the better ;)
You'd better get in touch with Mercedes, it's time someone with real insight told them they're doing it wrong...
Oh no! Based on Aarons' advice I just bought a 2 speed Powerglide tranny to go in my M35. Back to the drawing board I suppose.
Spool that baby up Leon; 8000rpm stall = mad skidz bro!
LOL at Aaron's successful trolololol
Nah mate - you haz ultimate- NO gears!
How'd that work out for Nissan :ph34r:
Too hard for Mr average no-brain to service with correct fluids at the correct intervals (on that note, I wonder how often - if ever - people change the filter near the cooler).
Nothing wrong with that transmission Alex, just the tool behind the wheel/under the bonnet.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
    • Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
