G'day guys, i'm looking for a towbar for a M35, now before you all tell me to do a search, ive already done that and found out about FastFit in Leichardt, but they won't ship the towbar down to Melbourne for me to get it installed locally, cost is $640 http://www.fastfitbu...au/towbars.html
Next i found this place in NZ but i've sent them several emails and hadn't had a response http://www.towright....wbar-21142.aspx
So i was wondeirng if anyone knew a place in Melbourne that install towbars for the M35.
If not it looks like a weekend drive upto Sydney to go to FastFit
Thanks
Chris
https://www.sau.com.au/forums/topic/395463-towbar-in-melbourne/
  • Replies 51
Short answer is: no, not as yet.
Long answer is: no, every tow bar place that have been called (there have been too many to list although I am certain not all of them) will not do a custom or non-ADR approved tow bar due to insurance issues. Custom tow bars need to go through ADR testing which is obviously not free and is time consuming so none have been willing to do one to date (even places that "specialise" in custom tow bars!)
Ok from NZ the bar is $617 NZD delivered to the door, (479.839 AUD) that is for either the
Class 1 - Handyman Towing
0kg to 1200kg
or the
Class 2 - Recreational Towing
1201kg to 1500kg
Then $352 install from Fast Fit in Dandy total cost $831
Might be worth the drive along the Hume
Which one? the one from FastFit or the NZ one? if the NZ one i would have no idea, but with the FastFit i would assume it's the same as Andy's http://www.skylinesaustralia.com/forums/topic/46643-tow-bars/page__hl__towbar__st__40
I think i'll just drive to Sydney for a weekend, at least i know what i will get.
Hey dale, what exactly have you towed?
Im wondering if the Fast Fit bar (and the m35 subframe) will be able to handle a car trailer + stripped out track car + a couple of sets of wheels, maybe a barrel or fuel and a tool box (that will sit in the boot)
Hopefully it can take it!
My trailer is an 8x5 box trailer with high sides and a checker plate floor; it weighs 270kg.
Loads; A tonne of Road base, a tonne of sand, a 1.2 tonne of firewood (all multiple occasions; up to 150 km)
Two sports bikes, ramps, fuel tools, gear over 2500km for the Phillip Island Ride day pilgrimage several times and a billion small trips to the tip with all manner of shite.
I don't know that I'd be keen to tow a car behind it; but that's just me. I can't see how you'd be under 2 tonne for you overall weight with what you're wanting; I think it's a bit much to ask of a towbar of this nature.
Edited by Daleo
I just got back from Locsed in Ringwood.
I showed him pics of the fast fit bar and he's pretty sure he can improve on it and get to at least 2000kg rated one. Will have the removable square tongue as well for about $900.
He's busy till Easter so will be done just after then.
Indeed, that seems to be a better option :P
ill have to weigh everything up, and probably delatage tools and wheels and stuff to other cars by the sounds of it.. i cant remember where but i read somewhere that m35's have a tow capacity of 1.6 braked
true? false?
I wonder if there is a discount to be had here for a group purchase?
  • 1 month later...
Hi Dasic, just wondering if you have had a chance to have this installed? Thanks
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
