Pick up from Blue Mtns or Sydney preferred.
Lay-By if your budget is tight - and you have up to 1 yr to pay it off.
Number 1)
Item: MINE'S CATBACK EXHAUST (R34 GT-R) for $790ono
Description: Rare & Beautiful 80mm S/S Exhaust. It has one of the most gorgeous tips too. System is not that old. So no scratches or dents.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/
  • Replies 76
Number 3)
Item: NISMO CALSONIC 3" S/S Exhaust (r34 GT-R) for $350
Description: This could be 10 yrs old - but good condition.
Lay-By will be accepted here too. Centre muffler has slight scraping, but nothing harsh.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283688
Number 4)
Item: HKS Front Pipe (R34 GT-R). $390
Description: This Y-Pipe has a foldover to equalize lengths > 3". Not that old. Gorgeous - no scrapes.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283692
Number 5)
Item: HKS 3" Cat. Looks like about 200cfm. $335.
Description: Heat shield and S/S Cat look to be in great condition. Minimal constriction at either end. No rattles that I can hear.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283693
Number 6)<br>Item: NISSAN Bonnet Struts for $0 = Free to a good home<br>Description: These need to be regassed. Want to make your engin bay look classy?<br>No Lay-By on these - LOL<br><br>Terry-225.jpg<br>
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283695
Nismo system should come up well with some elbow grease ie steel wool scourers
Yes it will, with some...
a) Prepsol 'n steel wool then
b) Autosol then
I think I'll have a go myself on the weekend if I have time and update Pics if it hasn't been taken.
Thanks
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284317
Terry, can you chuck up the sizes of the Hooker Muffler? (width and length)
Ta
A
Sure...
Without the piped flanges,
Body Width = 280mm
Body Length = 365mm
A, It comes with installation instructions + embossed words "INLET" and "OUTLET" on the muffler itself
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284327
Sure...
Body Width = 280mm
Body Length = 365mm
Cheers tez. Will measure under the car and let you know
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284529
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
